Results 1 to 13 of 18
    Feb 2017
    Gas fireplace or Wood fireplace?
    Gas fireplace or Wood fireplace? Which one is better?
    Jun 2015
    Milky Way
    It's all preference. I personally like wood better. Puts out a hotter heat but can get messy with all the ashes. I have a wood one now and use it more than I ever did with a gas one.
    Sent from my iPad using Tapatalk
    Sep 2015
    Ontari-ari-ari-o
    Two different things and two different applications. Gas fireplaces are more for supplemental heat and ambience and while wood fireplaces are often used for those things as well they are also used as primary heat sources and especially so in rural areas while most gas fireplaces aren't listed or certified as primary heat sources. There are lots of other considerations as well the cost of a new wood system can be double the cost of a gas fireplace and if a new chimney or venting system is required that can triple or quadruple depending on what is needed. Your insurance company might not be too keen on a wood system and raise your premiums and the local code powers that be might not even allow a wood system in town either. Then there is the maintenance and work required with wood which is much greater than a gas system.
    Bottom line is that if you live somewhere with lots of readily available wood and you want a source of heat go with wood. If you want a fireplace for the look or to take the chill off now and then a gas fireplace is the way to go.
  4. Likes DavidDeBord liked this post
  5. #4
    Apr 2017
    Canada, BC
    What I generally tell my customers is, from a usage perspective it's really about the fuel supply and how important convenience is.
    Wood is a tricky fuel to cost as it can be the least expensive or the most expensive depending on where you get it. If you live on a large property or can somehow supply your own wood then the cost is going to be your time (which is a big consideration), as well as vehicle and tool fuel (chainsaw), maintenance, and storage space. There is also a lag of two seasons before newly cut wood is "seasoned" and reaches the ideal moisture content for burning. This is an important consideration when comparing performance, and likely varies depending on your climate.
    There is also the consideration of mess inconvenience of starting the fire, and insurance companies aren't huge fans of solid fuel appliances, so that can be a bit tricky. Out here they straight up won't insure you if you say you are using a wood fireplace as a primary heat source, and certain things such as too much wood on hand can void your insurance as it is taken to mean it's a primary heat source or you wouldn't need that much wood.
    For advantages, wood heat is a drier hotter heat which many find especially comfortable. As has been mentioned wood can put out more heat, but these are space heaters. If you get a quality, efficient gas fireplace properly sized for the job you want it to do you will not find the volume of heat lacking. Gas got a bad name with some as there have historically been so many low quality builders boxes and decorative gas fireplaces installed which give little to no heat. Compare that to something in the 70%-80% (FE efficiency) range and it's night and day. Propane and natural gas fireplaces are also quite different beasts, so what is said of NG fireplaces does not necessarily apply to Propane.
    Gas fireplaces here tend to be comparable, if not more expensive than a wood alternative up front. The main advantage is you flip a switch and your wife is warm, or get a t-stat and you don't even need to flip a switch.
    I personally went with gas insert over wood as I live in a suburban area, have no wood access and didn't much like the idea of going to the wood pile every time the wife was cold (which is always). Wood is also expensive to buy here, and in many cases it is not so much seasoned as it is "seasoned".
  6. Likes DavidDeBord liked this post
  7. #5
    Jun 2017
    I prefer to the Gas Fireplace.
  8. #6
    Aug 2018
    I adore the charm of wood fireplaces!
  9. #7
    Mar 2015
    Hamersville, Ohio
    One advantage with Wood is that when the Grid goes down, ... Natural Gas & Propane will eventually Cease, whereas Wood will not.
    And Kyoufu, & Sooty, pretty much laid out the finer details.
    Myself, ... Going with a Gas Fireplace, is all show, whereas a Wood Burner is the "Real Meat" of the subject.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  10. #8
    Apr 2011
    Columbus Ohio
    I prefer the wood burner. Personal choice
  11. #9
    May 2014
    Bay Area California
    Yeah, I'm a wood burner guy myself. Takes a bit of practice and experience to get a quick hot fire, but once you learn how, you'd be surprised how fast you can get a hot smoke free fire going. Helps to have a source of free wood and the drive and energy to cut it up into sizes compatible for a fireplace.
    In my profile on this site, you may notice that under 'Interests' I put:
    Cutting down trees and chopping fire wood.
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
  12. #10
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by BBeerme View Post
    That is a Major Relief BBeerme, .... And here I was worried that You had some deviant Fetish with wood.
    LOL! I'm pullin' Yer Cahin!
    "Yeah, I'm a wood burner guy myself. Takes a bit of practice and experience to get a quick hot fire, but once you learn how, you'd be surprised how fast you can get a hot smoke free fire going. Helps to have a source of free wood and the drive and energy to cut it up into sizes compatible for a fireplace."
  13. #11
    May 2014
    Bay Area California
    Quote Originally Posted by DavidDeBord View Post
  14. #12
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by Mindrasect View Post
    I picked wood for 3 reasons: 1. Most reduced cost given our conditions. We have 40+ sections of land of lush land. We reap wood from just the dead/fallen trees, so our wood is free. Our companions encourage pull and slash as an end-result of free wood for themselves, and we make it a bit of trip/work-party. 2. We like the look and feel of a wood stove better. 3. Not reliant on any specialist organization/conveyance.
    Our one wood stove warms around 1/2 the house. I introducing a second wood stove this year which will warm the opposite side of the house and will likewise serve as a reinforcement stove/broiler. But I am confused which one is best for me. Please share your suggestions.
    Your "Reasons" are Very Good, so my "Suggestion" is to:
    "Get er' Dun!".
  15. #13
    Dec 2018
    Hello You can select wood stove from the following list -:
    1. Lopi Endeavor Wood Stove
    2. Vermont Castings Encore 2in1 Wood Stove
    3. Pleasant Hearth Wood Stove
    I hope you will like it.
