Results 1 to 13 of 25
    Portland
    you know your customer has had enough ..
    when they pay you to yank a 1 1/2 year old unit off the roof, rip off the curb and replace it all with Carrier equipment. this customer has had nothing but problems with a Sunliner since it was installed. multiple Simplicity board failures, constant fault code 9 issues, I even put 24 volt tattletale's on every single limit and safety trying to narrow down what was giving the fault and not a single one ever tripped. went through the harness and controls completely and never did find a reason for the constant issues. and it wasn't the same issue every time, it was random different stuff. when the customer was asked what they wanted us to do with the unit we removed their reply was dump it in the distributor parking lot.. it now sits in our scrap pile.
    you will attract more flies with honey than with vinegar, but you can attract the most with a dead cat
    Aug 2015
    Buffalo,NY
    Replace the contactors. We had a few units with similar problems. That's what the factory told us. I also went down the road with 24v tattletales and inline breakers ect. Replaces the contactors and everything went away.
    Jun 2012
    Northern NV
    ......and the curse of the $9 chinese contactor continues.
    Nov 2014
    Northern Idaho
    I have also seen a failed contactor cause odd issues on a york.
    Dec 2014
    You guys are causing @Bald Menace to pull his hair out! Oh wait.....hair? Probably as domed as me☺!
    Sent from my SM-G930V using Tapatalk
    Southeastern Pa
    There may be an issue with the contactors..... but I have two units where I replaced all the contactors, and the code nine persists.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    up in the hizzy
    One of our clients did the same thing, but he didn't change brands instead he threaten York (JCI) with legal action and got another York RTU for free, been a year or so since and so far no problems with the new unit.
    There is not better place for the working men than the union! 100% UA the only HVAC union!
    Dec 2014
    I see almost no Yorks. I do remember a small board that the tstat wires land on I think. Is that a lockout board or isolation relay setup or?
    Worked on 2, UCP units brand new, installed by someone else. Someone is installing a lot of them around here.
    Apr 2010
    I thought tattles tales were no good with most control boards? There's probably not enough current flowing through the safety controls to trip one even if it does open.
    I know they won't work with Carrier lock-out boards, cause it'll lock out quicker than a tattle tale takes to blow. That one took me some time to figure out. Maybe Simplicity boards are the same way?
    jci plus York = unreliability.
    or profit center all that jci really cares about.
    jci is the apitomy of hvac.
  11. Likes HeatenCoolair liked this post.
  12. #11
    Aug 2016
    PA USA
    I had same issues on one. Replaced both contactors, problem resolved. Ohm out the coils. I believe they should be 4-7 ohms. Thw ones i replaced were almost 9 ohms. With the higher resistance the board may not be seeing full 24 volts our of contactors causing error code 9.
  13. #12
    Portland
    one day I was there for a no heat again and had the unit sitting idle with stat wires disconnected from the control board. i'm sitting on hold waiting for tech support (I was number 32 in line) and out of the blue it starts flashing fault code 9...for no reason with no input from stat..
  14. #13
    Jan 2012
    Montreal, Canada
    Went back 3 times on a one of those for the same alarm. 3rd time . Went old school. No board .Relays tstat contactors .
    Sent from my SM-G900W8 using Tapatalk
  15. Likes Bald Menace, RV10flyer, BBeerme liked this post.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
