+ Reply to Thread
Results 1 to 8 of 8
Thread: Split bearings
    Western Wa.
    Split bearings
    Anyone ever use one of these split bearings? Slick as snot changing out a center bearing.
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
  2. Likes ruuufuhbock liked this post.
  3. #2
    Nov 2011
    CO
    nope, that's pretty sweet!!
  4. #3
    Southeastern Pa
    Cooooool.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #4
    Jan 2012
    Montreal, Canada
    Ive heard you need a dial to check space between bearing rolers and housing with the shaft suspended . If thats the same type Im thinking.
  6. #5
    Western Wa.
    Quote Originally Posted by DeniV View Post
    We had to move the bearing support as the bearing is thicker than a standard pillow block bearing.
    UA Proud
  7. #6
    Apr 2006
    mechanical room
    Swwwweeet
  8. #7
    Apr 2003
    St. Louis
    I have not used that brand but have have used other brands. on Evapco towers the blower shaft is 10' long and the center support bearing is in the middle. worked great. took a grinder with thin disk and cut the old bearing off
  9. #8
    New Mexico
    Only on hot rods.
    We are here on Earth to fart around ......Kurt Vonnegut
    You can be anything you want......As long as you don't suck at it.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
