Page 1 of 6 123456 LastLast
Results 1 to 13 of 66
    Nov 2014
    Portland, Oregon, United States
    Condensate pump power
    Question, I have been seeing slot of new installs where the company cuts the plug in off the pump, and wires it into the main electrical for the furnace, or in one instance clipped the primary to the xformer and wired nutted it there.
    Illegal right?
    I cornered the installer and he swears up and down it's fine. Code says that a receptical needs to be provided, non gfci.
    Should I push the issue?
    Sent from my SM-G935T using Tapatalk
    Aug 2014
    Va/Tidewater area
    Good question. I've replaced worn out pumps that were hard wired in to incoming air handler power. I guess I should have pressed for an outlet.
    Southold, NY
    must be GFI protected.
    If they go thru the trouble of hardwiring just install a box with a GFI,
    Southeastern Pa
    A note to all:
    You are not permitted by Code to cut off a plug from a flexible cord and wire it directly to anything.
    If a manufacturer provides a hard-wiring option for installation, you must comply with all requirements of NEC chapter 3, including conductors, raceways, device boxes, and terminations.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. Likes jmac00, buttwheat liked this post
  6. #5
    Nov 2014
    Yep. That's about what I thought. Do you have NEC reference by any chance. Common sense says it's a no no, but they do love chapter and verse here.
  7. #6
    Nov 2014
    Never mind. Duh. Sorry.
  8. #7
    Aug 2012
    just pay an electrician to run a new wire and plug AND make customer pay. why would manufactures even make a 240 volt pump? I know why because they know installer will cut wire and wire to unit. just another misconception by toocool.
  9. #8
    Southeastern Pa
    When I asked, I was told they made 240 volt single phase pumps so you can run a pair of conductors from a three phase delta panel, and install the special receptacle that matches the special plug they give you for the pump.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  10. #9
    Southeastern Pa
    Quote Originally Posted by technocratic View Post
    NEC 400.7 B requires the flexible cord to have a plug, so it would need a receptacle for the plug to connect to.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  11. #10
    Feb 2011
    Georgia
    I've installed 480v before.
  12. #11
    Aug 2012
    just run a long extension cord from the kitchen. batabing.
  13. Likes chrisevansac liked this post
  14. #12
    Rochester, NY, USA
    I absolutely HATE when some lazy POS 'Tech' cuts the plug of a condensate pump.
    every time I replace a furnace or for new construction, I install a 110v duplex on the furnace. This does two things for me
    1) a plug for a the condensate pump and a UV light
    2) a plug for a light or any other accessory that may be necessary during a service call
    The only down side I have found so far is some lazy numb skull plumber will use my outlet of a powered water heater.
    If I come across a hard wired condensate pump I will tell the homeowner that it's illegal and for a nominal fee i will add a outlet.
    PANIC
    Rarely works
  15. #13
    Dec 2012
    Lancaster County, Pennsylvania
    Quote Originally Posted by toocoolforschool View Post
    <snip> why would manufactures even make a 240 volt pump? I know why because they know installer will cut wire and wire to unit. just another misconception by toocool.
    Actually I had serviced an apt complex with 40 geos in closets and not a neutral to be found. That's why they make 240v condensate pumps and small fractional hp circulators.
  16. Likes Juan Madera liked this post
