Results 1 to 13 of 30
    Athens, Ohio
    Innovative but wrong
    Have a good look at the filter position with respect to the blower housing.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  2. Likes HeatenCoolair liked this post.
  3. #2
    Urbandale IA. USA
    INTERNAL filters are not allowed in Iowa, IF inspected...
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
  4. Likes tmt, ga-hvac-tech liked this post.
  5. #3
    Feb 2017
    Seems like more work to do that than to install it exterior to the furnace
  6. #4
    Jul 2013
    Richmond, VA
    Quote Originally Posted by cehs View Post
    Really? Why is that?
  7. #5
    purty much all filters should be installed "internal" maybe ask what "internal" means?
  8. #6
    Jul 2012
    WA
    I think I see that a lot, unless I'm missing something. Sure, it's not ideal but it works ok.
  9. #7
    Mar 2013
    Billington Heights, NY
    I see a bigger problem with the style of floor pattern
  10. Likes Red Man, buttwheat liked this post.
  11. #8
    Oct 2010
    Austin, TX
    Ohh no, no, kdean1, he mounted it correctly. That's one of those low-efficiency 50% filter systems.
    Lowers monthly cost on filter replacements by only affecting 50% of the airflow.
    I think it was invented by Homedepot purchasing department. They found by only carrying 50% of common parts used in each department you lower your overhead and get customers to spend an extra hour searching the shelves.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
  12. #9
    Jul 2012
    WA
    Quote Originally Posted by XcelTech View Post
    It looks like it's a left side return and the filter is completely covering the return. It's a sh!tty filter in a bad location, but it's pretty typical.
  13. #10
    Better then no filter
    not saying this is a grate install but at least it has some type of filter
  14. #11
    Oct 2010
    Austin, TX
    Quote Originally Posted by Red Man View Post
    You sure? That metal at the bottom looks like store bought sheet metal to me. The color doesn't match the thin Goodman style like you can see on the sides.
    I guess that could be dust making it look that way.
  15. #12
    Urbandale IA. USA
    Quote Originally Posted by CircusEnvy View Post
    Too many home owners and tenants do NOT know how to reinstall the cover panels and often do damage to the inner workings of the furnace. So to prevent that from occurring, they made it illegal and require filters to be changed without opening the furnace cabinet.
    It still might be done but not where an inspector will catch it.
  16. Likes ga-hvac-tech liked this post.
  17. #13
    Athens, Ohio
    The temperature rise on that furnace was 75*. Spec is 30-60*. Naturally it was cycling off on high limit. Numerous shortcuts were taken during the installation. Among them were using a 16x20 rack for a 28" deep furnace, return system is 3 wall cavities and 1-6" duct, cramming the furnace and atmospheric vented water heater into a bedroom closet with a solid door, and more.
    I'd never seen a filter rack used inside a furnace and putting it against the side of the blower housing ensured that it would reduce limited air flow still more. It all smacked of cheapest installer with the cheapest equipment. (That's why I put the door so part of the Goodman label could be seen.)
