Results 1 to 9 of 9
Thread: Carrier, defrost and freeze stat.
    Apr 2008
    Tucson, AZ
    RTU freeze stat had opened during defrost cycle. So compressor is off, Blower runs and makes the room even colder, 50*. Ambient 29*F. Jumped out freeze stat for awhile and started heating. 10 minutes in, freeze stat closed again, unit goes into defrost and indoor coil again gets below freezing. Turned it off for a couple hours as I was busy elsewhere. When I returned it was working fine, ambient 45*f. Room 72*f, Carrier says unit is good down to 25*f. No aux heat.
    Carrier, 50TCQA07A2A6A0A0A0, S#4411C80330.
    I need to go back and do some finer troubleshooting; just getting some ideas.
    Is it normal for a freeze-stat to trip in defrost?
    edmonds wa
    Do you have to much fresh air setting or is the econo driving open during defrost?
    UA Local 32 retired as of Jan 2020
    Apr 2008
    Tucson, AZ
    Quote Originally Posted by buford View Post
    I believe it is 5% minimum approx.
    edmonds wa
    Is the defrost stat in the right spot? Freeze stat is on the indoor coil, so yes during defrost that coil could drop the temp down, until the outdoor coil temp gets warmer. I have seen units with either too much outdoor air or the econo open during a cooling with compressor also trip them.
  5. Likes mccann liked this post.
  6. #5
    Apr 2008
    Tucson, AZ
    Ay, if the room is cold and cold outside it may be hard for that stat to close again. I assume it closes back around 45*f, but it's a klixon not a precision instrument. It would be nice to kick it back into heat in such a moment instead of just shutting off the compressor, Alas. Perhaps it stuck in defrost too long causing the too cold sequence.
  7. #6
    edmonds wa
    Is the charge good?
  8. #7
    Apr 2008
    Tucson, AZ
    Is the charge good?
    Good point. I did not have time to check the charge when I was there, but I certainly will.
    Question: If charge is low and I'm in heat; then in defrost; would that effect defrost termination or are you saying the indoor coil would get too cold in defrost because of that? Defrost is a max of ten minutes I think, unless the termination stat closes right? When it went into defrost, the outdoor coil got very warm so I was thinking perhaps the termination stat was sticking. I wish I had more time that day. I only had 15 minutes on the unit, alas.
  9. #8
    Jan 2017
    SE Ohio
    Like Buford said, check charge.
    Also check for txv on inddor coil. If it is restricting, and your freeze stat is close to distributor tubes, that (36 F ?) stat will open quickly. Let us know what you find.
  10. #9
    Apr 2008
    Tucson, AZ
    Quote Originally Posted by RV10flyer View Post
    I thank you all for your assistance. Alas. One of our other tech's want back because I was too busy. He changed the defrost board and outdoor stat, as that was my first guess before getting to put put gauges on it and talking to you folks. It's working now possibly because it's been warm at night. I doubt he did any further analysis. If I am on that building again this winter, I want to look into it more. Sometimes though I may not go back to a location for a year. Frustrating.
    Thank you all again for your knowledge.
