The proper way is to use a flush cart. Air bubbles will get stuck in the loop without the high pressure/ flow of a pump. All so your house water pressure may not be enough to pressurize the loop. There is a possibility you may contaminate your hoise water if any glycol back flows up the hose into the house. I would find someone else to finish the job the right way.
Sent from my SCH-I545 using Tapatalk
