Results 1 to 10 of 10
    Mar 2016
    Pahrump, NV
    Looking of a source of Red Brass RMC
    I am trying to find a source for 2" Red Brass RMC with 3 factory long radius 90's and appropriate fittings.
    I want to run a 40 Amp 240V branch circuit to a shed that I am building that will have a small mini-split heat pump, a light and 120V and 240V outlets for bench testing motors.
    The run will be buried just over 6" to avoid plumbing and the service feeder for my dwelling.
    Any suggestions will be appreciated.
    It's an upside down world we live in.
    Mar 2016
    Pahrump, NV
    Wow, big mistake on my conduit size calculations. I was using diameter and not area. So, I don't need 2", I only need 3/4". Unless, the numbers are still playing trick with me.
    For a product that is required by the NEC for burying cable less than 18", it is hard to find.
    Jan 2010
    How long is the run? Steel and aluminum options?
    Aug 2010
    Living rent free
    Sent using crapatalk.
    "If you can’t describe what you are doing as a process, you don’t know what you are doing." ~ W. Edwards Deming
    All those who wander..are not lost.
    Do NOT..mistake my kindness for weakness.
    The early bird may get the worm..but the second mouse gets the cheese.
    Aug 2010
    Living rent free
    Jan 2010
    That was my first thought. Then I noticed he's only going 6" deep which would require metal or brass. UF cable and PVC require 18" I do believe.
    Aug 2010
    Living rent free
    I would go overhead, before I ran metal conduit.
    Jan 2010
    I agree but he's probably thinking aesthetics. Who sells brass pipe ?
    Mar 2016
    Pahrump, NV
    I was interpreting "permitted" incorrectly for the red brass RTM. The code does say that galv. and stainless is permitted in all atmospheric conditions and occupancies, and then later that it is permitted in direct contact with earth.
    So, I will be going with good old galv. steel.
    Yes, it is for the appearance that overhead is not being done.
    Thank you for bearing with me while I struggled through this.
  10. Likes lions_lair liked this post
  11. #10
    May 2017
    this is very informative
