    Flame sensor system tester
    Someone mentioned to me that there is a tester available that will simulate a flame sensor that will tell me if the board is no good. He said you turn the gas valve off, hook up this tool, turn the unit on and the unit thinks that there is flame, even though there is no flame because the gas valve is off. If anyone can tell me what the tool is called, from my convoluted description, I would appreciate it. Thanks!
    They will soon forget how long it takes, but they will always remember the quality.
    Jan 2016
    The triangle in the Keystone
    http://hvac-talk.com/vbb/showthread....ster-Simulator
    This was just being discussed a couple days ago. Might not be exactly what your looking for but I hope it helps.
    Thanks! I didn't realize I posted in the electricians section.
    Oct 2009
    Atlanta,Ga.
    Johnson controls Flame simulator .Part number Y99AW-1C
    Apr 2012
    Chicago, IL
    Correct me if I'm wrong, but if you have the uA feature on your meter, do you still have to simulate it? If the flame rod is sending the signal and you're checking in series right at the board, then the board is bad. In my experience, flame rods don't really "go bad" if you can still clean them and the ceramic's good. They usually send a signal waaay higher than the threshold to rectify flame at the board.
