Results 1 to 13 of 17
    Jan 2017
    York RTU Intermittent running
    Ive got a York unit that has had an issue for maybe 2 weeks at this point and Im running out of options.
    York Mod DL-08N18PTFAA4 This unit had an ignition board replaced about a month and a half ago and has had no other issues. Owner replaced stat and that was checked and is operating normally. Now maybe once a day or every other day will stop running for a few hours and then just start right back up and cycle fine. The limit switches have been checked, no codes are coming up, airflow is fine, burner and inducer are clean and clear. Anybody got any ideas?
    Southeastern Pa
    My only idea is that someone has to be there when it stops running, to ensure there is still a call for it to run, and that power to the unit has not had an issue.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2010
    Which ignition box was the replacement ?
    Jan 2017
    This unit has two separate circuit boards, the board was replaced no ignition box. The new board was the same as the original.
    That is about the only option I can think of, is to actually be there when it happens. At first i thought it was tripping on a self resetting limit but both switches are manual reset and a code should have been flashing.
    Jun 2014
    Dover, DE
    Is this a 1A or SSE board?
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Jan 2010
    Quote Originally Posted by dmartin528 View Post
    So it's the York Simplicity Board ?
    Jan 2017
    I don't believe it's the simplicity board, this board is only for ignition and its in the compartment with the inducer and burner.
    The other circuit board gets all the stat wiring and is with the main power supply and contractors.
    I don't know if it is a 1A/ SSE board
    Jan 2017
    Hopefully I'm not confusing anyone when i say circuit board. The diagram says ignition control, but it is an actual board
    Jun 2014
    Dover, DE
    Pictures please
    Jan 2017
    Ill try and post them tomorrow when I get back to the job.
    Southeastern Pa
    There are two boards.
    A simplicity board is in the controls area, and a second heating board is in the burner section. Those burner boards had a high failure rate due to corrosion on the smuds and other devices. The replacement boards have a resin coating to prevent the corrosion.
    I have also found the units seem to require more frequent replacement of the induced draft motors. If a draft motor stops, it may not set a code. If the draft motor stops on the internal thermal overload, then it could start up again when the inducer and the overload cools down.
    That's my best guess.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. Likes hvacmatt123 liked this post.
  13. #12
    Nov 2011
    East Side
    You should have the simplicity board.
    If the older programming is the same as the SE boards, It will soft lockout for an hour after 3 failures, then retry. It won't show a code for that.
  14. #13
    Jan 2010
    Per your model number you have a factory installed smoke detector in the return air section. Have you looked over the smoke detector ?
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
