Results 1 to 6 of 6
    Help with Lighting Wet Room on Remodel.
    This is a Bath Remodel in my house. The area is 71" x 60" A 60' x 30" White Tub on the right, shower on the left. Shower is to have Matte Dark Blue Tile on floor, back wall, tub apron, and ceiling. About the color of Levi's washed a dozen times. Side walls and Tub faucet end wall are to be a glossy off white 12" x 24" tile. I'd like to use a flush mount ceiling lights, that are for a wet area, and I want to use LED lamps, with a standard screw base. BTW if someone can tell me how to post pictures, I can post the Architectural Drawings I did.
    Retired, after 43 Years
    Dec 2016
    Central Ohio
    Quote Originally Posted by madhat View Post
    So what is the question?
    Sent from my SM-N915T using Tapatalk
    Mar 2013
    Billington Heights, NY
    he wants to know what lights and cans we all would suggest.
    i dont know what cans but i do suggest a frosted daylight bulb. they "appear" brighter and have a cleaner light. temperature of daylight is between 5500 and 6500 kelvin.
    Oct 2018
    I believe 4000k is natural...5000k and more feels like you're in a lab
    Atlanta GA area
    Quote Originally Posted by mtlmonk View Post
    Yes... 4K is more or less neutral...
    Yet true daylight (outdoors)... is more like 5-6K... yeah, seems strange.
    Note the type of bulb makes a difference...
    As the light from a 4K flourescent looks different than a 4K LED
    GA-HVAC-Tech
    I used an elco can, new construction, for direct insulation contact, wet area, and installed a wet area LED Retro fit. It's too yellow for the tile we picked, but I haven't replaced it yet. I have checked it for condensation , and it was dry. BTW it has a styrofoam insulation box over it, that's sealed to the Wedi Board tile backer.
