Results 1 to 13 of 19
    Aug 2009
    Maine
    Middleby pizza oven
    A bit out of my element. Customer says when he turns on the oven the blower doesn't come on. If he goes and resets the circuit breaker everything works as it should. I was thinking it could be a control board issue but really have no idea. I suppose I could run the blower from a switch but don't want to "hack" it.
    Oct 2016
    Iowa, USA
    Depends on the model of the oven.
    sent using crapatalk
    Feb 2016
    N'awlins Dawlin' USA and Palmares Costa Rica
    I've had some good luck finding manuals and tech info here but need the model number:
    http://www.cpsohio.com/
  4. Likes firume liked this post
  5. #4
    Oct 2016
    Iowa, USA
    Quote Originally Posted by davejohnsonnola View Post
    Hell, I think parts town even has the service manuals for Middleby marshall
  6. Likes CFESAmasterEGSR liked this post
  7. #5
    Jan 2016
    The triangle in the Keystone
    It really does depend on the model. An old PaceSetter compared to a WOW will have a different diagnosis for the same problem. And a board for either is really really expensive.
  8. Likes CFESAmasterEGSR liked this post
  9. #6
    Oct 2016
    Clearwater, Florida
    Might be a faulting relay on the board, you could try to find out which relay runs the fan and see if it switches by measuring the backside pins of the relay, should be able to get a P/N on the part and look it up, will tell you the switch configurations.
  10. #7
    Aug 2009
    Maine
    I know its fairly new. Guy promised to get the numbers for me last Sat.
    Quote Originally Posted by VanMan812 View Post
  11. #8
    Well marc until he gets you what you need it don't get fixed
  12. #9
    Aug 2009
    Maine
    True dat.
  13. #10
    Aug 2009
    Maine
    Mod. PS555G
    Ser. S10373011
  14. #11
    Feb 2016
    Jan 2016
    Which blower is he talking about? I see it's a gas fired oven so it could be the burner blower motor or the air impingement motor.
  16. #13
    Feb 2016
    checking out the diagrams on pages 170 - 171 there are two blower motors- left and right, one burner blower motor, and two cooling fans.
