Results 1 to 7 of 7
    Jan 2013
    Western Ky
    Heat of extraction formula
    What formula do you use? Is delta t of water x gpm x 500 for water (pump and dump) aka open loop correct ? If so how do you get your gpm? Is the flow restrictor size good enough or ?.
    Oct 2010
    For pump and dump I use a 5 gallon bucket and a stopwatch.
    Jan 2013
    Western Ky
    Sounds interesting lol
    Jan 2006
    Harrisburg PA
    measure entering water pressure before it enters the unit (PT port) and pressure exiting the unit (PT port). Every manufacturer ive seen has a chart in the product specs that will show you the gpm at a measured pressure drop at a certain temperature. Pretty easy when you see the chart ....make sure its for the right size unit. That same chart will give you your heat of rejection/ extraction
    Jan 2013
    Western Ky
    Feb 2015
    Jan 2013
    Western Ky
    Awesome download thanks
  8. Likes Carbent liked this post
