    Apr 2008
    Delray Beach, Florida
    NEW STYLE A/C DRAIN PAN SECONDARY OUTLET FLOAT SWITCH
    NEW MODEL AA2-FS CONDENSATE OVERFLOW SHUT-OFF SWITCH
    Installs On Primary & Auxiliary Drain Pans
    UL LISTED AND TESTED TO UL 508 (CODE APPROVED)
    LET ME KNOW YOUR THOUGHTS ON IT. I REDESIGNED MY ORIGINAL TO MAKE IT MORE RELIABLE.
    https://youtu.be/sdT-4DeR1Ok
    [VIDEO]https://youtu.be/sdT-4DeR1Ok[/VIDEO
    Dec 2003
    Citrus County, Florida
    There is a safety switch out there that you can unscrew from the AH. When changing a coil this is handy as the entire switch can be removed. I hyave them on the truck and do not remember the manufacturer or model number.
    Doug
    Apr 2008
    This one has a switch that can easily be replaced if necessary without removing the device.
    Apr 2008
    Could be Drain Alert
    Apr 2008
    HERE IS MY LATEST REDESIGN MODEL OF MY OLD SS2.
    Model AA2-FS
    Quote Originally Posted by soaker View Post
    Apr 2008
    I have had requests for samples. Let me know you company name and address. Send it in a private message.
    Model AA2-FS
