+ Reply to Thread
Results 1 to 15 of 15
Thread: Sloan Flushmate problem
    Mar 2016
    Pahrump, NV
    I have a customer with a Kohler rear outlet residential toilet that has a Sloan Flushmate pressure vessel Model No. M-101526-F3 Series 503 installed sometime between 2005 and 2009.
    The vessel has a leak at the midline seam. The Customer wants to have a standard flush assembly and fill valve installed to replace the Flushmate.
    Do you know if a standard flush valve can work with a rear outlet Kohler toilet. My local supply house no longer carries Kolher, and they didn't know the answer.
    I'm calling the Flushmate service number tomorrow, but I was hoping to have ideas before I call them.
    Thank you in advance.
    It's an upside down world we live in.
    Mar 2016
    Pahrump, NV
    Here are a couple of pictures in case that helps.
    Jan 2010
    I don't think so. The trapway design is different for the Flushmate.
    Mar 2016
    Pahrump, NV
    VTP99,
    A reputable plumping supply house in Las Vegas, as well as Flushmate service personnel confirmed that a gravity flush system cannot be used with a rear outlet toilet.
    The Flushmate model my customer has is subject to a recall for the problem that I found. They will send a free replacement vessel, but it will take several days to arrive.
    The customer is stuck with a rather expensive pressure assist rear outlet toilet. Unless of course, he wants to spend a whole lot more money redoing the sewage system, septic tank and all.
    Thank you for your input.
    Jan 2010
    I've never seen a rear mount toilet around these parts. Probably be a real conversation piece. Would also be real easy to clean down around there. I like that idea. But yeah, most our toilet plumbing is in the basement or under a slab.
    Mar 2016
    Pahrump, NV
    Unlike a commercial toilet, this doesn't hang on the wall. It still rests on the floor. So, no benefits for cleaning.
    Sewage line doesn't have enough slope to change it to a bottom discharge. I don't know why the house was built this way. There may have been some reason the septic tank couldn't be dug any deeper, or this bathroom might have been an add-on later.
    Mar 2016
    Pahrump, NV
    Excellent service from Flushmate support. They have sent me a replacement under their warrantee program. It should arrive in a couple of days. Flushmate will also cover my labor to R&R the unit because the customer is handicapped and he can't do it himself.
  8. Likes VTP99 liked this post.
  9. #8
    Mar 2013
    East Concord, NY
    Im late... but yes there has been a large recall of these tanks due to leaks and explosions.
    Nest is POO!!
  10. #9
    May 2014
    Bay Area California
    For what's it's worth, at least information for the future, Kohler has some customer service that no other company can match.
  11. Likes HVAC_Marc liked this post.
  12. #10
    Mar 2013
    East Concord, NY
    Quote Originally Posted by BBeerme View Post
    Except, with a Sloan Flushmate based system they will refer you to Sloan, because of the recall.
    Nest is POO!!
  13. #11
    May 2014
    Bay Area California
    Still getting free parts, right?
    Quote Originally Posted by HVAC_Marc View Post
  14. #12
    Mar 2013
    East Concord, NY
    Sloan is giving the new flush tank kit free, yes. Kohler still gives free parts covered under whatever warranty they offer, usually their "leak-free" clause. But, Kohler is not giving out free flush tank kits.
    Nest is POO!!
  15. #13
    Jan 2010
    I don't know who's giving free stuff out but can I get on the list ?
  16. #14
    May 2014
    Bay Area California
    If, for example, you buy a faucet from Kohler, then it is warrantied for life. That's how you get free stuff.
  17. #15
    Mar 2013
    East Concord, NY
    There are some exclusions, but most everything is covered.
    Nest is POO!!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
