Page 3 of 7 FirstFirst 1234567 LastLast
Results 27 to 39 of 85
  1. #27
    Southeastern Pa
    Quote Originally Posted by toocoolforschool View Post
    Pronlem is customers looks at technician who has never been their before and says i think your trying to rip me off. I just bought the thing a yr ago. Hey don't worry backordet is only three weeks we can bury grandma after her heatstroke.
    None of that is in my world.
    I am thankful for that!!!!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. #28
    Etters PA.
    I had problems with Frigidaire Mc on furnaces. They have a static problem. I no longer use nordyne. York uses Mc also on some of there products. I just looked into Rheem that my distributor is picking up and they had an aluminum tube/fin coil so I'm not sure if they are switching to that or if they still produce the mc. Looks like nice equipment but I'm not sure of there reputation.
    Sent from my SM-N920P using Tapatalk
  3. #29
    Dec 2014
    Quote Originally Posted by hedrash View Post
    Very similar. More like an expansion tank. One pipe in & no outlet. Fills up with condensed liquid.
    Sent from my SM-G920V using Tapatalk
    Just looked that up. I've not seen one. Are they just on resi, high efficiency heatpumps?
  4. #30
    Jun 2016
    Plano, TX
    Quote Originally Posted by icy78 View Post
    No, they're on a lot of equipment. They're replacing accumulators as they're smaller & more efficient since we have TXVS on most equipment. They act like a receiver. With a TXV the refrigerant backs up, fills the compensator & there's no need for an accumulator.
    We can control fire & ice.....
  5. #31
    Dec 2014
    Yeah I guess I'll have to read more about them. It seems to me that their application would be for heat pumps with a varying load between heat and cool and where does the extra refrigerant go if it's a mismatched system. The Emerson site would not load up for me on my phone . I wonder if anyone has a link to a compensator interior breakdown and description of its intended use.
  6. #32
    State College, PA
    From what I understand about micro channel systems, you can not mix & match. Both indoor & outdoor needs to be micro channel or both tube coils.
    Someone please correct me if I am wrong. Rather be wrong here than on a service call trying to figure out why it is not working.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  7. #33
    Jul 2016
    Quote Originally Posted by joemach View Post
    There are quite a few that are mix matched per say. Usually see more systems with micro channel condenser and tube evaps. Just lately been setting pack units where both coils are micro channel. Only done a few splits where both were micro channel.
    Sent from my SM-G900P using Tapatalk
  8. #34
    Etters PA.
    I don't think that is the case at all unless it is specific to a brand you work on. York and Nordyne it is not.
  9. #35
    May 2014
    Bay Area California
    In the commercial work I do, lot's of micro channel condensers, and no micro channel evaps.
  10. Likes icy78 liked this post.
  11. #36
    Jun 2016
    Plano, TX
    Over the years evaporators have come a long way. 26 fins per inch, thinner wall tubing & the evaporator coils tend to use rifled tubing to spin the refrigerant evenly across the surface area.
  12. #37
    EXIT 16W www.wmtandson.com
    If you can?
    describe the compensator and its location
    Add a compensator. Will resolve all of your issues. My guess is they'll all come with one in the near future.
    I had similar problems with water source heat pumps that were 410A. 60-70% came 10-12oz over charged. (Mcquay/Daiken were the WORST)
    DON"T mess with the US
    I thought I had been there and done That.
    ITS ALL ABOUT LEARNIN!
    I thought it would be better by now
    "He who works with his hands is a laborer.
    He who works with his hands & his head is a craftsman.
    He who works with his hands, his head & his heart is an artist."
    ~St. Francis of Assisi
  13. #38
    Southold, NY
    Quote Originally Posted by epacertified View Post
    If you can?
    http://www.emersonclimate.com/Docume...ompensator.pdf
    http://www.emersonclimate.com/Docume...(PA-00380).pdf
  14. #39
    Jun 2016
    Plano, TX
    If you can?
    Charge Compensators
    The ACC charge compensator increases system efficiency by storing extra refrigerant in the heating mode then returns refrigerant back into circulation in the cooling mode.
    Designed to work in heat pump and micro-channel applications. The heat pump ones look like this, the suction line cools the refrigerant & keeps it as a liquid. Acts like a receiver for liquid refrigerant.
    The ones for micro-channel applications look like a 162-S filter drier with only one inlet. You tap into the liquid line with a 3/8"×1/4"×3/8" T & run a 1/4" line to the compensator which is mounted on the sheet metal using a "U" strap. During low load the compensator acts like a receiver, holding liquid refrigerant & keeps the unit from tripping on head pressure.
