Results 1 to 9 of 9
Thread: lighting on contactors
    Virginia
    I have one restaurant that has contactor boxes for the lights , dining area has one , kitchen has one , and another area has one
    Why ?
    Mar 2013
    Treasure coast, FL
    Because the lighting load may exceed the rating of the light switches?
    Sent from my SCH-I545 using Tapatalk
  3. Likes Jettinvr6sc liked this post.
  4. #3
    Jan 2010
    EMS (Energy Management System) ?
  5. Likes Jettinvr6sc, ga-hvac-tech liked this post.
  6. #4
    Virginia
    yea I was thinking too many amps for a switch , but why not add another switch instead of 500 dollar relay box
    I will snap pics
  7. #5
    Required by code?? We have the same thing at work. Low voltage at switch, with relay box in electrical room for 277. Also there is some kind of latching circuit on the outdoor lighting. If it doesn't see a current draw, shuts the circuit down. This is giving the electricians a fit when the upgrade to LED.
    Also did you know NEC my outlaw multi-gang switch boxes? May not be anything above two gang. Reason is two many dimmers are being placed in a multi-gang switch box. Already local code in some places.
    Retired, after 43 Years
  8. #6
    Atlanta GA area
    Built one of those back before HVAC... outdoor lighting for an industrial building... TOO many amps for the sunlight sensor. Simple box and a 30A 2 pole contactor.
    Used to blow the sunlight sensor every 6 months... never did after the relay box.
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
  9. #7
    Cincinnati, Oh
    My grandpa's house was wired that way.
    Designed and built the house himself. He was an old school electrician at the power plant.
    Had a huge panel above the door frame of my grandfathers room.
    He said:
    "your dad, when he was a boy, was a moron. I was seriously afraid he would kill himself by playing with a switch."
    Not that it helps, but I remembered it and thought to share.
    "Just get it done son."
    Dad adjusted
  10. Likes johoff34 liked this post.
  11. #8
    Southeastern Pa
    Just a quick note for you guys in case you have to replace a lighting contactor....it is a different grade of contactor than we use in rooftop units, and it must be the correct type for the purpose. In other words, it must be "listed."
    Word of warning: if you give a quote, make sure you get the price first.... because lighting contactors are waaaaaay more expensive than refrigeration contactors.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. Likes Jettinvr6sc liked this post.
  13. #9
    Mar 2014
    Grand Blanc
    Quote Originally Posted by hvacvegas View Post
    That's hilarious. Thanks for sharing
    Sent from my iPad using Tapatalk
