    Jan 2015
    East Tenn
    Exclamation Anyone Have Coating Spec's for the Condenser Coils
    Anyone Have Coating Spec's for the Condenser Coils ?
    Better Yet just have Manufacture send over a Copy of Cert - If No One Knows . . ( All You Tech's ) Haaa
    Cert's are Required By Manufacturing Contract Full Fulfillment - for - Any Plating Std's. Period ..
    Where's would be the Cert's Kept ?
    Who's Got the Certs ?
    Even in a lot of - Acid Rain - this will inform - You All - How long the Coils will Last . . all the Rest is just BS
    Jan 2015
    East Tenn
    Sorry but Some just like Calling Names - that Certainly Shows their Intelligence !
    OK
    1. If You don't have the Cert for the Material - You don't know - how it was Annealed or Type .
    Then You need to measure it's Thickness .
    2. The a Cert is needed for How the Plated Part was Prepped , Type of Plating and it's Thickness .
    3. Then You would need another Cert for the Finishing - Sealing - Coatings .
    Where are the Cert's ? - as - Good Manufactures aren't afraid to show the truth ..
    Aug 2013
    Visalia California 93291
    Don't know of any coated condenors unless specially ordered from the OEM
    Jan 2015
    East Tenn
    I Highly Doubt Manufactures put Raw Aluminum in their Coils on either Inside or Outside Units .
    They would Spec It from the Manufactures of the Coils and it would have to Pass through approx 2 Inspection Phases with Certifications
    Attached or Materials would Not be Accepted . read ( Let Into the Plant for Assembly )
    Anyone with Bad Coil or Coils going Bad - the - Vendor that Produced Component would be Fully Held Liable . . Also ..
