Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 70
  1. #27
    Jan 2010
    Sea to Sky
    Quote Originally Posted by HVAC_Marc View Post
    Wow, we had a brownout here yesterday with the AC running, and today my AC is still maintaining 68 degrees. It's R22. Maybe it has an internal Kinuten Valve that protects it from these surges...
    No way....it is the Icecold baby!!!
    Sent from my SM-N910W8 using Tapatalk
  2. Likes HVAC_Marc liked this post
  3. #28
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by BALloyd View Post
    Im on a different system now. Divorce, apartment, an Amstrong MagicPak. Maybe I should plop some in there and see what happens...
  4. #29
    Jan 2010
    Sea to Sky
    Nah. Try that Bluemaxx crap. I am sure the oil must be fouled in it.
  5. Likes HVAC_Marc liked this post
  6. #30
    Apr 2003
    Maple Grove, MN
    Ummmm...yes they do. Simple frequent temperature changes will do it. So will a chronic moist environment.
    Did you say chronic? Now it's starting to make sense.
    If at First You Don't Succeed, Skydiving Is Not for You.
  7. Likes HVAC_Marc liked this post
  8. #31
    Jan 2010
    Sea to Sky
    The are no brownouts in BC. We have excess hydroelectric capacity. We are usually selling excess generated power to California.
    Quote Originally Posted by timebuilder View Post
    Okay. I read some more, and he used the term, "Hydro." That's a Canadian term for power companies, thanks to Niagara Falls Generating Station.
    Now, maybe there's a lot of brown outs in Canada. My dad never mentioned having that problem in British Columbia, but then again he had to carry a bucket down to the stream to get water to make breakfast in Nelson.
    If there is a pattern of burned wiring, my sense is that there is a very much larger problem afoot then simply a voltage loss, which is typically referred to as a brown out.
    Terminals in equipment are generally rated for 75C, and the insulation is often rated for 90C. In order for a wire to burn off from a terminal, the quality of the connection must be low enough to create a resistance, which acts like a heater.
  9. #32
    Southeastern Pa
    Quote Originally Posted by QualityAssure View Post
    Sorry I got Off Track , started talking about Claim Coverage & Self Protection
    If they need to File a Claim with the Electrical Co . __ They have Proof - that Equipment and Connections were all OK . .
    Their Meter & BOX and A/C Disconnect Switch were all Good to Go ( In Writing like a Bill )
    There seems to a be a lot of Power coming from Nuclear power , TN The Hydro Power was put installed in the 40's and 50's so a lot of it is Pretty Old.
    They Do Switch Overs Everyday .
    They Don't always get it Correct .
    There also seems to be Issues as I'm Told from several Near-By's and Seniors in the Area ..
    At Least 3 I Know of Personally - were all - Loose Wires .
    WIRES DON'T LOOSEN ALL ON THERE OWN ..
    Yes, they do. See above.
    Changes in voltage have nothing whatever to do with what you are observing. A few short duration
    transients will not loosen connections.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  10. Likes lions_lair, jmac00 liked this post
  11. #33
    Aug 2010
    Living rent free
    It's obvious, he has a beef with the power company. Just EXACTLY why, who knows or cares. It's his agenda.
    sent using crapatalk.
    "If you can’t describe what you are doing as a process, you don’t know what you are doing." ~ W. Edwards Deming
    All those who wander..are not lost.
    Do NOT..mistake my kindness for weakness.
    The early bird may get the worm..but the second mouse gets the cheese.
  12. #34
    Mar 2013
    I bet he wears tinfoil hats and drives the ever-more-polluting eco-car with eco-fuel, too
  13. Likes lions_lair liked this post
  14. #35
    Aug 2010
    Living rent free
    Probably didn't pay his bill last month, and got terminated. Now he wants to slander them into oblivion.
  15. Likes HVAC_Marc liked this post
  16. #36
    Jan 2015
    East Tenn
    Yeah , they don't have the Foggiest - a Brown Out is NOT a Surge !
    Also Please Check to see How may Amps - that R22 Motor can Pull and Remain COOL . . If there isn't enough Voltage the
    Motor is Pulling more then Normal AMPS . .
  17. Likes HVAC_Marc liked this post
  18. #37
    Jan 2015
    East Tenn
    Your Definition of a Few ? + Plus 1
    Your Definition of a Short Duration Transients ?
  19. #38
    Jan 2015
    East Tenn
    From Input from any others , about Lost Equipment and Issues Repeating over and Over .
    My First ? to all of them was Why are the Cable Grounds and - Under Grd. Telephone line under ground 40 Yr. Old HD Copper - all - being Grd to each Homes Main Grd from Main Electrical Box.. well Daaaa ground Spikes backing up - into Home Main Box .
    Hell Lets tie in Everyone's Well Pumps also .
    LOL and If they have back up Power lets Grd that to the Neighbors Main Box or the Telephone CO Under Grd ( Grd )
  20. #39
    Jan 2015
    East Tenn
    PS : Local Electrical Co thinks were all Hicks and can do anything they Please ..
