Results 1 to 10 of 10
    Nov 2008
    Altamont, IL
    265 V. Whats up with this?
    Was in a school classroom watersource heat pumps. Labeled 265V. That's on a single breaker and 265V. to ground. small 1 ton sys. Never seen this set-up. Any comments?
    In GOD We Trust
    Oct 2010
    Quote Originally Posted by jdwendling View Post
    277/480 volts is fairly common in commercial/industrial.
    LEHIGH VALLEY, PA
    yes i was looking for a 120v off a light in a walk in cooler, a few weeks back , luckily i checked before connecting 270v there
    Jul 2012
    WA
    277 is one leg of 480 to ground.
    edmonds wa
    Its also quite the shocker to your body to ground.
    UA Local 32
    Western Wa.
    Just one leg of 480v. Very common in large commercial buildings as lighting
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
    Nov 2008
    Altamont, IL
    This is 265 v Equipment (small watersource heat pumps) nameplated for 265v. Tecumseh hermitec labeled 265v. blower motor also.
    In GOD We Trust
    Apr 2010
    Austin
    Oct 2010
    Iirc a 265v appliance will work with 277. I think it's made for Europe or something where their service is 265/480? (Maybe I dreamt that though).
    I'm sure Timebuilder knows enough about it to make your head spin.
    Oct 2008
    You have utility supply voltages of 120, 208, 240, 277, 480, then there are the rated voltages of 115, 200, 230, 265, 460, that are used for motors & welding equipment, in the 50 hertz world they use 380Y/220V, 400Y/230V, 415Y/240V, because of some countries using 380/220V, & others 415/240V, the EU harmonized it to 400/230V, quite common in Germany to use 400V 3Ψ for a domestic electric range, 277 volts is pretty much a American voltage, Canada uses 600Y/347V, 277V & 347V are both line to neutral voltages, so single pole breakers would be used in a panel.
    PTAC's are available with 265V
