+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
Thread: WHY IS IT ALWAYS GOOMAN ?
  1. #41
    Jul 2000
    Guayaquil, EC
    Ok, moving on, I haven't ordered the TXV's as of yet. Typically I use the Sporlan balance port Q valves. Yes, No, Maybe ?
    Good choice. They tend to provide better control over a wider range than the standard valve. They're about the same price as the Q valve too, aren't they?
    I had Q-Kit since shortly after they came out back in the 90's. The BQ's came out later on. I never did upgrade to the BQ-Kit because my supply hose was so slow to build their stock of BQ parts.
    Anyway, i never had issues ithe the Q's, but if the cost and availability were the same I'd opt for the BQ.
  2. #42
    Jan 2010
    Thanks guys for your input. Always appreciated.
  3. #43
    Jan 2016
    The triangle in the Keystone
    [QUOTE=icemeister;23293731]You guys have it figured out correctly. The major issue you may find with such installations is the installer didn't "get it" and failed to do even the minimal necessary mods to the unit, like a start cap & relay, dual pressure control and a receiver.
    How would I "size" the start cap and relay for something like this? Are you talking about the cycle count per day from the high temp to medium temp setup?
  4. #44
    Jan 2016
    Quote Originally Posted by icemeister View Post
    I haven't plotted it out either, but with a rough interpolation I estimate around 11.2°F TD or 23.8°F evap temp for 37,740 Btuh based on the 90°F ambient condensing unit capacity tables.
    Any chance you have some literature available that explains this? A link perhaps
  5. #45
    Jul 2000
    Guayaquil, EC
    [QUOTE=VanMan812;23307031]
    If it's a Copeland, just look it up the Electrical Handbook for what relay and cap your compressor model calls for. Nothing more involved than that.
  6. #46
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by VanMan812 View Post
    Here's a past thread where I explained about the system balance point:
    http://hvac-talk.com/vbb/showthread....orator-TD-help
  7. #47
    Jan 2016
    [QUOTE=icemeister;23307111]
    So a modification to the existing start package is not necessary? I ask because I service a bar with a margarita machine that is remoted to a condensing unit on the roof that is, I believe but have never confirmed, way over sized. It cycles on and off CONSTANTLY. It goes through start relays and capacitors like candy. When you talked about modifying that high temp unit to be used in the medium temp application you had mention considering the start relay and cap as a necessary minimal mod. Could undo something about my current situation? I don't have any specs on the unit, I haven't had a service call on it in a while. This thread just made me think of it.
  8. #48
    But can the Genie lift run to the parts store for you or get you're lunch
  9. Likes JohninJoliet liked this post.
  10. #49
    Mar 2013
    Treasure coast, FL
    [QUOTE=VanMan812;23307291]
    Install an EPR valve on the unit to reduce it's capacity. You'll probably need to set it to about 0 degrees SST.
    The starting components are required for the A/C condensing unit to reliably work as a pump down unit. If it came with them already, then there's no need to add them.
    Sent from my SCH-I545 using Tapatalk
  11. Likes JohninJoliet liked this post.
  12. #50
    Mar 2013
    Treasure coast, FL
    Oh! Also; does your start capacitor have a bleed resistor across the terminals? If not - install one.
  13. #51
    Mar 2014
    Charlotte, nc
    They could have at least squared it up with the pad.....on a side note looks like stick copper so no option of a gradual bend either huh
  14. #52
    Mar 2016
    Pahrump, NV
    Anything built by man, can be rebuilt by a good man. However, it is not always a good man who works on a Goodman.
    It's an upside down world we live in.
  15. #53
    Apr 2016
    Joliet
    In my opinion, portions of this thread hold really good basic refrigeration knowledge and ought to be copied to the education forum. A couple of real world issues presented with logical Q&A progression!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
