+ Reply to Thread
Results 1 to 17 of 17
Thread: Any other cause other than bad compressor? (Noise)
    On a bull named Foo Manchu
    Video says lil Harley but it sounds just like a old 3 cylinder Saab
  3. Likes UmmScott liked this post.
  4. #3
    Aug 2013
    Omaha
    Lolol.
    Sounds like a broken spring mount or something
    Sent from my SM-N920V using Tapatalk
  5. Likes fridg liked this post.
  6. #4
    Jul 2000
    Guayaquil, EC
    I agree it sounds like an internal mount has failed. I've seen it a few times. One in a restaurant on an old top-mount reach-in lasted like that for years.
  7. Likes fridg liked this post.
  8. #5
    Feb 2007
    Ohio
    Yep, broken mounting spring internally. Have seen em last years that way.
  9. #6
    Jan 2010
    I had a customer who couldn't stand the noise and had me change it out even though it worked fine.
  10. #7
    It had a 30 mfd run cap
    While running it tested 25 mfd with my Fieldpiece SC640 that I don't use much and 28 mfd with my Fluke 87v with i200s clamp
    Both meters read 30 mfd reading directly with cap our of unit.
    Suction line was cool but pump gets hot and shuts down.
  11. #8
    The unit is less than a year old
  12. #9
    Feb 2007
    Ohio
    Same here, 3/4 H.P. single door freezer, noisy as hell. He trashed the whole thing and bought a new freezer as replacing the compressor would have cost more than half the price of a new one.
  13. #10
    Feb 2007
    Ohio
    Still in warranty then.
  14. #11
    Jan 2016
    The triangle in the Keystone
    The last time I ran into a "broken mount" was on a mug chiller behind a bar. Due to the location and the noise the owner wanted the pump changed out. Once it was out and I got it home I cut it open to see what exactly happened. The "broken mount", in my case, ended up being a vibration absorbing spring had somehow jumped off the tab it sits on.
    I didn't, but I wonder now if I had slid the spring back on and secured it and the welded the little tin can back together, would it have worked? I'm a crap welder so probably not!
  15. #12
    Feb 2007
    Ohio
    LMAO.....
    We can reuse him, he will live again...
    Quote Originally Posted by VanMan812 View Post
  16. #13
    Jan 2010
    An Indian engineer I met on a job told me in his homeland they repair tin cans.
  17. Likes ReferTroop liked this post.
  18. #14
    that sound would not bother me as long as it worked i would run er till she goes belly up
  19. #15
    Jul 2000
    Guayaquil, EC
    I had a customer whose father owned an electrical shop in Bombay. He told me the same thing including rewinding the motor. He said a new compressor might be more expensive than in the US, so it pays off since you can employ a technician for $30/month.
  20. #16
    Jan 2010
    Quote Originally Posted by icemeister View Post
    Hey, as long as you're a good welder why not.
  21. #17
    Apr 2005
    Australia : Queensland
    Just making the shells room bigger ,,,nothing to see here,,,, could be El Chappo digging another tunnel.....
    Agree ,,internal failure ,,,, could run for years if the noise is not an issue ,, could be a stretched spring if the motor had been stored on its side ,,, quiet possibly could have been dropped just before install.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
