Page 6 of 6 FirstFirst 123456
Results 66 to 72 of 72
  1. #66
    Sep 2019
    According to York they stated 24 volts runs through the heat limit and back to the board where it monitors it regardless of heat call or cooling. I found it weird as well. But issue went away, will update upon switch replacement if it happened again prior to returning.
    If you ain't have time to do it right, then you must have the time to do it twice. 😊
  2. #67
    Southeastern Pa
    Quote Originally Posted by FixitFelix View Post
    ....and that is what you call a bad design.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  3. #68
    Sep 2019
    Joliet, Il.
    May I have a copy of the manual as well?
  4. #69
    Sep 2019
    Don’t have one I’ll try get a schematic. Haven’t been back, another technician replaced the switch, unit hasn’t been down since, been over a month.
  5. #70
    Nov 2019
    Access to manual?
    I can not access this manual. I am dealing with a multiple call back on a York RTU which is erroneously engaging the heat cycle.. and full heat cycle in which valve opens and igniter is lighting?
  6. #71
    Southeastern Pa
    What have you tested so far?
    What were the results?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  7. #72
    Southeastern Pa
    Quote Originally Posted by Drae K. Osburn View Post
    One more thing.
    Please do not post your need in someone else's thread.
    Next time, start your own. Give the model, serial, etc, and state your issue.
    Thanks.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
