+ Reply to Thread
Results 1 to 14 of 14
Thread: flame on
    flame on
Size:  114.1 KBName:  IMG_0045.jpg
Size:  190.9 KBName:  IMG_0046.jpg
    Nice to see an AlliedAir install... that is my primary brand.
    We have the AirEase... which IMO is a hokey name...
    Wish we had ArmstrongAir...
    So... is it a VS furnace... most of mine are...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
    Oct 2010
    Looks ok. A few things I likely would've done different but overall pretty good.
    Gotta rib you a little bit...
    Is that a combustible on the lower right... within 1" of the furnace wall...
    GA-HVAC-Tech
    yes it is. stat box, gave to homeowner. no vs, 14 seer rated at 16? didn't like outdoor infront of meter and panel but that was where it was and really nowhere to move it without a lot more $$$ and work
    We have a serious humidity issue here in HOTlanta...
    Once folks experience a VS furnace... they never go back.
    Figured the location below the meter was one of those: no other choice... things.
    Would not pass inspection here...
    GA-HVAC-Tech
    Western Wa.
    If you pulled an electrical permit you are going to fail inspection. You blocked off the access to the electrical panel it must have 30" of clearance.
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
  8. Likes johoff34 liked this post.
  9. #8
    the line with the line dryer in it is way to close to the exhaust flue.
    and the out side unit would be red tagged and shut down in Maine no access to the panel behind the unit.
    other wise looks nice
  10. #9
    You can thank Misters Johnson and Olsen for that
  11. #10
    Aug 2015
    Buffalo,NY
    flame on
    I would of ran my lineset in some slim duct to the left and put it I front of that bump out that has siding on it. Or it's an external chimney. Either way that would not of been an expensive add on to get it out of that corner with more room to work on it.
    Believe nothing you hear, and only half of what you see! Sent from my iPhone using Tapatalk
  12. #11
    Western Wa.
    Sorry but I had to double check and see what wall of this was posted on
  13. Likes Metalman0880, johoff34 liked this post.
  14. #12
    Used to be a couple of ArmstrongAir suppliers in the area... they seem to be drying up (or I do not know who carries the brand now).
    There are a handful of small suppliers who handle Ducane or Concord. One of them is thinking to take on ArmstrongAir again (again, as they used to handle it).
    My main supplier, CC Dickson, was bought by U/R...
    While UR 'says' they are gonna continue to handle AlliedAir...
    IMO (and others opinion also)...
    UR already handles ICP and ThermalZone (Rheem)...
    They will figure out a way to phase out AlliedAir.
    I am looking around now...
    Not sure if I will stick with AlliedAir,
    Or switch.
    A local Mom/Pop shop... is an ICP shop...
    EXCELLENT customer service! ! ! ! !
    May well go that route...
    Rheem is in the running also... but they are costly!
    CHANGE seems to be in the air... we will see.
    One name that is NOT in the running: Ruud.
    The local supply house let go my local branch manager... for questionable reasons.
    I am one that deals with the manager... not the shop...
    And now that he is gone... that shop is not somewhere I want to deal with.
    GA-HVAC-Tech
  15. #13
    Mar 2014
    Grand Blanc
    Don't like the condensate drain being tied into a smaller copper line. Wouldn't of ran lineset in front of coil and exhaust piping. Condenser completely blocks off all service are for electrical panels. Would love to hear the electrician who gets called out there.
  16. #14
    i have to ask what is with the hanging non secured GFCI outlet by the left side of the unit.
    that would be a red tag in my area by any inspector
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
