Results 14 to 17 of 17
    Where the grass is green and the girls are pretty
    Great post!
    I've found too many of those tan box relays failed to count. The rating must be wacked or the engineers who designed them into their machines are wacked.
  2. Likes ECtofix liked this post
  3. #15
    Jan 2017
    shreveport la
    wise words spoken!!!!!!
  4. #16
    Jan 2017
    shreveport la
    it has been a learning expeirence
  5. #17
    Jan 2017
    shreveport la
    update on gw 24 glassd tender, if youre having a problem with drain stopper not dropping fast enough(all the water running straight down drain) and you verified h2o flow, and thermocouple on in coming hot water line is good. take a hard look at the drain switch on bottom, corrosion inside the switch caused it to give false signals to control module.
    just passing some info along.
