    Jul 2016
    North Central California
    Drought effect on geo thermal
    I have not done any geothermal but my first step in investigating it is about heat transfer in the soil.
    California has been experiencing drought and I've noticed the ground is very dry.
    Does the moisture content of the ground have a major effect on the heat transfer of the circulating water?
    Nov 2000
    Upstate, SC
    Depends on what you consider major, but you should be able to look at the product data for the brand you are considering and then look at different soil types to answer your question.
    Bobby
    Jan 2014
    Quote Originally Posted by californiajim View Post
    YES.
    A 4 ton ground loop in moist soil could be 1/2 the size of a 4 ton loop in bone dry soil. The moisture in the soil will greatly effect the radius of heat transfer around each tube in the ground. Think of dry soil as insulation, and wet soil as nice shiny aluminum fins that like to transfer even minute temperatures differences.
