Results 1 to 2 of 2
    Jan 2015
    East Tenn
    #2 oil furnaces - Anti Gel - Stopped Up Issues .
    First of All and one Spending that Kinda Money - Could have Installed a 220 Volt Hybrid Tank 60 Gallons
    Which also Keep Your Basement Cooler and Dryer - those - Run all Yr. for $198.00 Bucks Family of 4 ..
    OK
    Anti Gel & Bug Killer , so they use to call it ..
    When looking @ all the Oil in Holding Tank - Shut the Main Tap Off and Hook Up
    Separate Line with Twin Quality Filters on It and a 12 Volt Pump .
    About an Hour Later Cycling the System through the Twin Filters which is about 2-3 Times Volume and
    Adding the Anti Gel - Entire Time just making Sure the System is Clean ..
    Compressed Air - doesn't Clean the Bottom of the Tank - just the Line !
    Also Spiders will make Web Nest etc. in the Vent ..
    Jan 2012
    Broomall, PA
    Uh......what are you talking about...and do you have a question?
    If you're talking about cleaning all the crap out an old oil tank, you obviously figured out you didn't do it correctly. You need to either vac it out...with a special vac, or with your pump, wash it down and out with filtered oil.
    This is done all the time in Europe. Here, usually they try treating the tank, lifting the supply line a couple of inches, and eventually replacing the tank.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
