Results 1 to 8 of 8
    Mar 2016
    UV leak detector glasses
    I figured this would be the perfect place for this question. So I was at the supply house today getting a new YJ micro LED dye kit and I didn't see the yellow glasses. I asked the guy at the counter and he couldn't find a replacement set, only a pair that came in the uv lamp kit. What's up with that, can you not get just the glasses?
    Dec 2003
    Citrus County, Florida
    Spectronics has a light that you can use that does not require the yellow glasses.
    Doug
    Aug 2009
    Maine
    Is that the 120 volt flood light? Now another question. Are the JB and the Spectronics compatible. I have used the Spectronics for well over 20 years. Just came across a system with JB dye in it. So will my light work on it?
    Quote Originally Posted by Gunslinger View Post
    Mar 2016
    I believe that is the 120v flood light. And I would assume one would work with the other, as long as they're both uv dyes. I just like to have the glasses so my customers can see what I'm seeing if they are older or if their eyesight isn't so good etc...
    Dec 2003
    No the Spectronics light is battery operated rechargeable. Optimax 400 I think is the model.
    Doug
    Jan 2014
    Bloomington, MN
    The glasses are available separately. The part number is 69415. If you need to find someone in your area who carries them, please call our customer service department at 800-769-8370. Thanks.
    Mar 2016
    Quote Originally Posted by YELLOW JACKET View Post
    Thank you much I will give that number to my supplier on monday
    Aug 2009
    Maine
    So can I use my spectronics equipment with JB dye?
