    Apr 2005
    Australia : Queensland
    Post-Mix CO2 Leaks.
    Customer has gone through a D size CO2 bottle in 2 days & normally takes a month. So going by this I would say it could be a sizeable leak.
    How do you guys look for CO2 leaks on Post-Mix Equipment & associated lines & Bar-Guns ?
    Is it just knuckle-down & get the soapy-bubbles out & check all possible options ? I have had success using this method but it can be time-consuming.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
    Jan 2010
    Get a co2 leak detector
    Apr 2005
    Quote Originally Posted by kevincompass View Post
    Would a personal detector do the same if used as a held-held ?
