+ Reply to Thread
Results 1 to 9 of 9
Thread: CAP TUBE TERMINATION
    Jan 2010
    anyone doing this 🔻
    Virginia
    to help ensure the braze doesn't clog it ??
    Jan 2010
    Not sure because It's the first time I've seen this done.
    Jul 2000
    Guayaquil, EC
    Was that brazed into a filter-drier?
    I can see that angled cut would prevent a restriction if you were to insert the tube too far into the drier...like up against the inlet screen. So on a factory production line it would make measuring the proper insertion length unnecessary.
    Jan 2010
    icemeister, in the 2nd. photo your looking at a 3/16" liquid line coming from the filter. I had removed the cap tube from there. I like your thought thou, it would act as a measuring stick for a filter insersion. Maybe the engineer was thinking more area for less chance of a blockage. Or well maybe it's a production process......
    Mar 2016
    Pahrump, NV
    It is "pinched off", right? Not cut at an angle.
    Jan 2010
    Quote Originally Posted by David Goodman View Post
    It's cut like that OEM, a first for me.
    Jan 2012
    Montreal, Canada
    It is to prevent restriction.
    Apr 2005
    Australia : Queensland
    This is to make sure the bore is fully open ,,, only down side is if your capillary rests up against the wall you end up with a blockage or restriction. We stopped doing this in the manufacturing environment for this very reason.
    We went to straight cut , check your bore , push your capillary in 50mm & make sure it doesn't bottom out , if so bring it back a bit.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
