Page 1 of 7 1234567 LastLast
Results 1 to 13 of 86
    May 2014
    Bay Area California
    The Double Flare
    There seems to be a lot of problems with techs making troublefree flare connections. The way I was taught decades ago was to first cut your tube. Then ream it. Then file the end square. Only after that could you get your flare block out.
    Ever see anyone file the end square?
    Now keep in mind, the bulk of my career has been troubleshooting, field service and/or emergency repair. So yeah, you can probably do it faster with a drill motor, but never having a leak at a flare fitting is quite a claim.
    The first three photo’s is my flare kit. And just to show you how much care I have given my flare / swage kit over the past few decades, notice it is still in the original cardboard. Probably needs a bit more duct tape.
    May 2014
    Bay Area California
    This series of shots shows the double flare ‘accessory’. Notice I use the ‘thickness’ of the head of the double flare accessory as a depth gauge. Then I put the tool inside of the tubing and run the flare tool down. Then I pull the ‘accessory’ out.
    This de-forms the tubing as shown.
    Then I run the flare tool down again.
    This gives you the double flare. That extra step of removing the ‘accessory’ takes at most fifteen seconds.
  3. Likes kdean1, trippintl0 liked this post.
  4. #3
    May 2014
    Bay Area California
    And that folks, is the beginning of a leak free flare.
  5. Likes kdean1, icy78, johoff34, HVAC_Marc liked this post.
  6. #4
    Jan 2010
    Sea to Sky
    Kinky.
    Sent from my SM-N910W8 using Tapatalk
  7. Likes UmmScott liked this post.
  8. #5
    Dec 2012
    columbus, OH
    Never had that problem personally . the coil will prolly leak first
    Sent from my XT1080 using Tapatalk
  9. #6
    Mar 2006
    Thanks for the pics
    Ive never seen a flare like that, maybe i have but never paid attention.
    If i had to put in a flare i just bought the pre made ones and brazed it on, the ones i last found leaking were single flare, i was testing at 300 psi, maybe it was to much pressure for the single flare
  10. #7
    Feb 2007
    Fremont, Indiana
    That imperial set was my very first flare kit (I think I still have it)
    Never used the double flare adapters (came with all of them), and never knew how........
    Thanks for sharing
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
  11. Likes BBeerme liked this post.
  12. #8
    Athens, Ohio
    I've never seen a double flare before. Thanks for posting the pictures.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  13. #9
    May 2014
    Bay Area California
    I have never in my life bought a pre made flare.
    Quote Originally Posted by marter View Post
    Thanks for the pics
  14. Likes kamersoutdoor liked this post.
  15. #10
    May 2014
    Bay Area California
    Your kit came with the double flares? Awesome. I had to buy each one separately.
    Quote Originally Posted by kamersoutdoor View Post
    Thanks for sharing
  16. Likes kamersoutdoor liked this post.
  17. #11
    Feb 2007
    Fremont, Indiana
    Thanks for the pics
    I always cut out the pre flared ends. When making the flares, the machine stretches the neck, making them weak, thus I never use the first 6" off a minisplit lineset.
    A Einstein
  18. #12
    Aug 2008
    Hibbing, MN
    BBeerme, I've got the exact same kit and have used it for over 24 years. Last year, I got a new case from my supply house because the old one was more shot than yours.
    I've used the double flares a lot on brake lines on autos, but never thought of using them on refrigeration. Thanks for the post.
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
  19. #13
    Mar 2015
    Medford, N.Y.
    Nice BBeerme, nice. Got a Q for you! Whats all that "discoloration" on the cover of the kit, on the inside bottom of the kit, and on the flare block & yoke& other pieces????????????????? Oh, I get it! Experience!!!!!!!!!!!!!!!! NICE!
  20. Likes jayguy, BBeerme liked this post.
