Results 1 to 13 of 22
Thread: Hammer drill
    Apr 2011
    Cayuga, In
    Hammer drill
    Looking for some info on a good economical hammer drill for knocking holes in blocks. Wondering what you guys are using and like, and what to stay away from. I know hilti is premo but pricey. Going be one of those tools you only need every once in a while. Thanks guys.
    Aug 2009
    Maine
    I have been thinking about the Milwaukee m18 1-1/4 M18 fuel
    Quote Originally Posted by shaworth1 View Post
    Sep 2012
    On the Job in TN
    I use a Bosch rotary hammer. Quick and efficient no matter what size of opening you need.
    Apr 2016
    Ohio
    I have a Bosch HD21-2, and it has worked great, but if you wanna make larger holes go with something that has spline drive.
  5. Likes ga-hvac-tech liked this post
  6. #5
    Dec 2009
    Roswell, Georgia
    I have 100% Milwaukee tools, have the M18 fuel and the bigger ac powered one as well. Both work well ....
    Know your limits - I have the # of the concrete 'boring machine (water drill) ' guy when the concrete is old hard and thick! 300 bucks a hole, but the homeowner pays it not me. Have to use them when we do minisplits sometimes ... 3" diameter hole.
  7. #6
    Oct 2010
    I use a hitachi spline (DH38YE). Have had it for 7 years or so with no problems. I don't know how you could live without one. Makes a nice clean 2 or 3" vent/comb air hole in any type of masonry in minutes.
  8. #7
    Aug 2009
    Maine
    That is why I am thinking about replacing my 1959 Milwaukee. Can't get parts for it. The 2-1/2 core bit is wore to hell.
    Still works awesome though, Just don't makem like they used to.
    Quote Originally Posted by bhahvac View Post
  9. Likes ga-hvac-tech liked this post
  10. #8
    Jan 2010
    Sea to Sky
    Quote Originally Posted by Carey Scott View Post
    Charge that $300 to 5 customers and you just paid for your own coring drill.
    Sent from my SM-N910W8 using Tapatalk
  11. #9
    May 2014
    Bay Area California
    Pretty sure mine's a Bosch. Those 'new' roto-hammers are totally sweet. Especially with those SDS bits.
    If you ever used the old style, I'm talkin' over 30 years old, they were absolutely miserable !!
    Keep in mind, with the newer style out there these days, gentle pressure will drill faster, make the tool last longer, and is easier on the hands. Did I say these new roto-hammers are totally sweet?
  12. #10
    Mar 2016
    Dayton Oh
    Bosch Bulldog is good for drilling under 1.5" and it also has a hammer/chisel mode. Anything bigger get an SDS, but then your talking some bigger money. I think you can pick up a Bulldog for >$200 and a lowes type store. Or if you need bigger holes and they dont have to be pretty, can always drill a bunch of 1/4" holes around the perimeter of the hole then chisel it out.
    The bulldog is nice because its case is no bigger than a sawzall case and can fit on the truck without taking up to much space. The SDS is more something I keep in the shop unless I know I am using it that day then I get it. Would say its case is something like 2' x 2.5' by 6" thick?
  13. #11
    Mar 2016
    Dayton Oh
  14. #12
    Nov 2001
    Port Saint Lucie, FL
    Bosch Bulldog SDS. I have been using it for 10 years, works great.
  15. #13
    Atlanta GA area
    I have a Bosch also... not sure of the model #...
    It is SDS style bit, angle motor, and will rip apart concrete.
    It has the regular drill, hammer drill, and chisel options.
    I have put a 2.5" coring bit into it... and drilled through brick and block.
    When I need a hole through a poured basement wall... I call the guy with the concrete cutting and boring co...
    My time is better spent on the install... that fighting a drill for 30 minutes.
    GA-HVAC-Tech
