    Santo Domingo,Dominican Republic
    30GTN alarms t-500 and T504
    I am having alarms T-500 and t504 on a GTN080 after changin the MBB ,this alarm are not even in the alarm charts ,any help?
    Dec 2009
    TN & MS
    If you press escape and enter on the scrolling marquee or on the navigator it will give you the alarm description.
    "The race is to the driven....not the swift."
    Dec 2009
    TN & MS
    You have enough post, apply for professional membership and you will get more help. I can't find that alarm in the manual either, so start by getting the code description. My guess it's a communications error.
    Ohio
    This is from a 30RAP but I highly suggest you look into this.
  5. Likes Chasespeed liked this post.
  6. #5
    Hardin, TX
    Quote Originally Posted by zw17 View Post
    He is probably correct. There was some mention in a training class a while back. I have never actually seen a GTN with a current sensor board. If you could post your full model number and the first 5 of your serial number I can double check. My first guess though is you have the wrong version of the software loaded into the MBB. Given that you show as being from the Dominican Republic, there may also be some issues with export controls, but check with your local distributor that the board is loaded properly for the unit.
  7. #6
    Nov 2019
    T 500 alarm in chiller
    [QUOTE=csavinon;22560231]I am having alarms T-500 , after changing main PCB in chiller 30GT515165
