Results 1 to 4 of 4
    Apr 2016
    11 (not 12) lead dual voltage motor
    Looking for a wiring schematic for old 11 lead westinghouse motor. The motor has 2 start capacitors and 11 leads. The motor was removed by another person and he failed to ID what and where when he unwired it. The motor has a data plate that shows an 11 lead wiring diagram for both voltages but nothing on how the 2 capacitors are wired. Another problem is the motor actually has 10 leads not 11, I'm thinking it was rewound and two of the wires were connected internally. If I can find a schematic I hope I can figure this out. Any help would be appreciated.
    rt
    Sep 2014
    Los Angeles
    Was this to be hooked up for high or low voltage application?
    Apr 2003
    St. Louis
    take the motor to a motor shop and have them wire it. if you wire it wrong you might let the smoke out!
    May 2018
    MN
    Kind of sounds like an old part start motor
    Sent from my iPad using Tapatalk
