Results 1 to 13 of 28
    May 2014
    Bay Area California
    Mine's Bigger Than Yours
    My start relay is bigger than your start relay. Well, it's certainly heavier, that's for sure. At almost 50 pounds. The pictures don't seem to do it justice, but here goes.
    I've always been curious what type of application it was made for. I've seen current versions of part winding start, just curious what type of three phase start application this was used on.
    Fairbanks Morse is still in business, wonder if they'd have a clue . . . ?
  2. Likes hvacker liked this post
  3. #2
    Apr 2011
    Coastal Maine
    On the industrial side, I used to run across the occasional Fairbanks Morse Generator or Fire Pump. These were primarily in textile mills and the equipment dated back to the 1920's and 30's. I would guess this was from one of those. Nice find.
  4. #3
    Mar 2015
    Medford, N.Y.
    The BIDDING starts at $50.00!!!
  5. #4
    PHM already has one as a door bell ringer
  6. Likes crazzycajun liked this post
  7. #5
    May 2014
    Bay Area California
    LOL
  8. #6
    Aug 2013
    S C
    Manual reduced voltage starting switch. You only have the handle and the hold in solenoid coil. I worked in a foundry once that had a 250 hp sand mixer that had a reduced starter . The motor had two different windings. Pulled the handle to start and when it got up to running speed, you slammed it in run. You had to be quick. The contact points were about 2 inches square and submerged in oil.
  9. #7
    May 2014
    Bay Area California
    Found it on a road trip a couple of decades ago, yard sale. Think I showed up about the time the guy wanted to close up. I kept checking it out, I probably showed more interest than anyone else he had ever seen. Can't remember if I paid anything for it, but if I did, it was only a couple of bucks.
    $50.
    Do I hear a $100 ??
    Quote Originally Posted by TechmanTerry View Post
  10. #8
    May 2014
    Bay Area California
    Sounds good. So pretty much the same as the part winding start of today. Just done manually?
    Quote Originally Posted by deerslayerjohn View Post
  11. #9
    Aug 2013
    S C
    Quote Originally Posted by BBeerme View Post
    Yes
  12. #10
    Feb 2016
    Chattanooga, TN
    They used to make diesel engines for WW2 submarines (Gato class?..Balao?) they were opposed piston engines and were actually pretty reliable compared to the GM recips that were also available. Really neat design.
  13. #11
    Southeastern Pa
    Quote Originally Posted by mitchellpsp View Post
    Never seen one of those subs. The last one I saw was the Clamagore, a Guppy III upgrade down near the Yorktown and Hunley In Charleston, and it had four Detroit diesels.
    https://www.patriotspoint.org/explor...uss_clamagore/
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  14. #12
    Mar 2015
    ARK.
    That thing come with a wiring diagram?
    Very Kewl BB.
    No matter how long you have been doing this,
    Go back and reread the Basic's.You WILL Learn something.
    Why is it called,an Act of GOD when IT has Nothing to do with Him?
    Will of the Devil would be more appropriate IMO.Just Saying.
    PSALMS, 18 & 25.
    I am Tired of High Efficiency Propaganda.
  15. #13
    May 2014
    Bay Area California
    No wiring diagram, what you see is what you get.
    Quote Originally Posted by mrkelly View Post
    Very Kewl BB.
