Page 5 of 6 FirstFirst 123456 LastLast
Results 53 to 65 of 66
  1. #53
    Southeastern Pa
    Quote Originally Posted by rcstl View Post
    R2D1????
    Close. I think it would be R12 D2.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. Likes ga-hvac-tech, ryan1088 liked this post
  3. #54
    Am I the only one who got it lol
  4. #55
    Aug 2010
    As I read the actual law the prohibition is not on refilling. What is prohibited is transporting the cylinder after it has been refilled.
    What is interesting to me that originally not-refilling relied entirely on the integity of the user to ensure compliance. But as soon as reclaiming became the law-of-the-land and recycle cylinders were routinely available for sale - the user intergity was apparently deemed to be lacking as anti-fill check valves suddenly appeared on all other cylinders. <g>
    PHM
    More importantly, it prevents back washing to protect the quality of refrigerant as well as hazardous pressurization. Those two outweighs the value you'd get from reusing the empty tanks.
    If you didn't have check valve and accidentally opened high side into it, you back washed system's charge into the virgin refrigerant by the time you realize it.
  5. Likes joejax liked this post
  6. #56
    Feb 2016
    Florida
    Hey ICanHas, stay tuned for the badass smoker I'm building!
  7. #57
    Beautiful, Philadelphia, the City of Brotherly Love!
    Made a bbq grill out of one, cut in half slightly above centerline weld bottom handles to plate steel or something to provide stability, use top for lid, add hinge if desired. Used an old commercial condenser fan blade cover as a metal rack for cooking surface and drilled a few holes for air intake.
    A buddy took 5 cylinders provided by your's truly and made a cool water gizmo out of them, one filled with water and then dumped into another, doing so caused the dumping cylinder to knock against another like a clunking bell. His wife put up with it for a summer and then it went to the scrap yard. He is on to higher grade projects these days, things people buy as art.
    “You don't get paid for the hour. You get paid for the value you bring to the hour.” Jim Rohn
  8. Likes joejax liked this post
  9. #58
    Feb 2016
    Florida
    Man, I played hell getting these to post. Have been working on this for quite awhile, shortly after start of thread. It's all made up of junk I had laying around, except the 2 pipe fittings on the top tank and the stack on top.
    Please excuse my awful welds, I am still learning and believe I am getting better. Some think my smoke pipes are too long and will not produce enough heat, I built a small fire and had about 180 to 200 up top and awesome smoke.
    I'm still not done, need to fit the lids better, grind poop welds, secure grids, and paint.
  10. Likes ga-hvac-tech, VTP99 liked this post
  11. #59
    Feb 2016
    Florida
    The top is an old well tank. The bottom is 3 404 jugs, I burned both in a bon fire. The bottom most is an old condenser cover piece and the jugs are cut all the way out as a rectangle, with custom vent holes and damper.
    Holding that up is pieces of a stand and a recycled ash catch. The stand is for a 55 gallon aquarium. The 2 feed tubes are from a futon frame. We have had some much needed rain so now it is a little rusty.
  12. #60
    Apr 2016
    Hi im new here..im an install tech not an owner. Anyways at the company i used to work for was a guy who used the empty 410 tanks as portable camp stoves. Cut em in half, weld hinges on the back, weld a handle on the front. The carry handles of the tank are now the feet, and then weld brackets inside to accomodate a small grate. Hook up propane to the refridgerant orfice in the bottom or use coals.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  13. Likes joejax liked this post
  14. #61
    Feb 2016
    Florida
    Thanks cobra, and welcome to the forum. I would like to see some pics of that, even though you described it well, sounds like a good project.
  15. #62
    Aug 2010
    are you mikey poodle head's boy?
  16. Likes joejax liked this post
  17. #63
    Feb 2016
    Florida
    Quote Originally Posted by ICanHas View Post
    Ha ha ha...I am literally laughing out loud over here....No offense Mikey, love ya like a brother, but that is funny!
  18. #64
    Jun 2009
    northern Ohio
    I read in Ducks Unlimited once to cut a hole in them and mount them to trees in the woods along creeks/marshes. Wood ducks will use them as nest boxes. Always have said Im going to do it but never have.
  19. Likes joejax liked this post
  20. #65
    This is only an intermittent answer - but you can take it to the bank in the short term:
    An angle grinder will make a sh!t weld into a pretty weld in almost no time. <g>
    It's not an end-solution but it will help get you through until you become truly great at welding. Which you will - if you just keep at it and remain unsatisfied.
    PHM
    Quote Originally Posted by joejax View Post
    . . . . Please excuse my awful welds, I am still learning and believe I am getting better . . . I'm still not done . . .
    PHM
