Results 1 to 20 of 25
Thread: Kold Draft Icer
    Mar 2015
    Medford, N.Y.
    Kold Draft Icer
    I am doing a job that spec'ed a Kold Draft 1000lb a day Ice Maker. Its been 20 years or more since I had the pleasure of working on a Kold Draft.They kinda went out of production way back when. Anyone use them, work on them?
    At The Point Of No Return
    We get speratic calls on them
    Southold, NY
    I've got 3 out here. (In an old KG Brown dispenser) Still chugging along.
    See if you can spec the Hoshizaki IM500***. I have one of those and much nicer machine.
  4. Likes UmmScott liked this post.
  5. #4
    Better I don't know...
    At least it would be easier to get tech support and parts
  6. Likes UmmScott liked this post.
  7. #5
    Oct 2012
    Wisconsin
    They still make Kold Draft. I had a warranty call on a new one a while back.
  8. #6
    Aug 2009
    Maine
    They used to be in PA.
    Quote Originally Posted by Mike19 View Post
  9. #7
    Aug 2013
    Omaha
    We sold one, its been a very reliable machine. No problems so far except for a stuck bin control.
    Sent from my SM-N920V using Tapatalk
  10. #8
    Mar 2015
    Medford, N.Y.
    I'm just an installer on this job,I'm helping out an associate.Then maybe, I'll be the Service Guy.
  11. #9
    Jan 2013
    florida
    the tech support is pretty good when you need it actually, i just started working on a few the last year or so, still prefer hoshi's though...
  12. #10
    I've never been able to get someone at Kold Draft tech support while one a job.
    If they call back it's next day or two if at all.
  13. Likes UmmScott liked this post.
  14. #11
    Feb 2016
    Florida
    Kold Draft's are a marvel of modern engineering. Take the front cover off and let the show begin.
  15. #12
    Quote Originally Posted by joejax View Post
  16. Likes joejax liked this post.
  17. #13
    Aug 2009
    Maine
    That doesn't look any different than the ones I worked on it the 70's
  18. #14
    Feb 2016
    Florida
    I love it iceman! Why change a good thing, lytning? Wooooo!!!! In your face, Scotsman!
  19. #15
    May 2008
    South Florida
    Kold-Draft has a new undercounter self contained that uses the same technology but has the evaporator slanted with a water plate that travels down 2", staying parallel with the evap. No swing so less space needed. Still has the same Big Square Cube.
  20. #16
    That under counter sounds a lot like one ice o matic has their name on too
  21. #17
    Quote Originally Posted by lytning View Post
    They keep making little tweaks with parts but basicaly the same.
    Lately the been through so many water pump styles I can't keep in straight and the latest water level sensors are floats. Looks like two marshmallows floating in a test tube lol
  22. Likes UmmScott liked this post.
  23. #18
    Quote Originally Posted by FSE_ View Post
    Re read that. Sounds nothing like I-O-M
  24. Likes UmmScott liked this post.
  25. #19
    Aug 2013
    Omaha
    Yes on the pumps...theyve changed them so many times. Now theyre this tiny tiny DC motor that has an inverter board that you mount and wire up with it
  26. #20
    Jan 2013
    florida
    i was sent on a call that they had numerous problems with, a couple different companies changing boards, floats, many parts, even a compressor, but it all ended up being install related, so i had the guys cell # so i could send pics and such, that could be why i never had a problem getting through. But i don't use that number for general question calls, and still have not had much problem getting through, i used to have that problem with manitowoc, by the time they would get back to me i would be three service calls down the road,they seem to be getting better too...
