Page 7 of 7 FirstFirst 1234567
Results 79 to 86 of 86
  1. #79
    Aug 2013
    Visalia California 93291
    Quote Originally Posted by anthonyac1 View Post
    I think your right on this. Lead end is the same as shaft end. I was taught lead end is always the rear of the motor regardless of the wire location. But this doesn't mean Im right. I emailed a.o smith/century regarding this question. Once they reply back I'll copy/paste their response to this thread.
    Lead End is where the leads come out of the motor and is opposite shaft end CCW LE and CCW SE is different unless the leads come out on the shaft end
  2. #80
    NH
    Lead end and shaft end are the same on this 276 CCW motor... only reason I know is because I just put one in...
    It is listed as CCWLE and it spins CCWSE. Not sure why they wouldn't just list it as CCWSE on the box and save alot of frustration.
  3. Likes VTP99 liked this post
  4. #81
    Mar 2015
    Medford, N.Y.
    Where did both of those fan blades come from?
  5. #82
    Aug 2013
    Omaha
    The blade on the right is the one thats supposed to go in the condensing unit.
    The motor bracket and blade on the left is just for example. ...they're spare at our shop
    Sent from my SM-N920V using Tapatalk
  6. #83
    Aug 2013
    Omaha
    Ok guys...got another one taken care of.
    I got that 75 watt motor installed. I also was able to evenly bend back the LAU fan blade to make the pitch less.
    Started up...took right off, not overamping. All is well for now
    I took some pics. Kinda suck tho lol
  7. Likes Mike19, trippintl0, BBeerme, VTP99 liked this post
  8. #84
    May 2014
    Bay Area California
    I'm a sucker for a happy ending.
    Quote Originally Posted by UmmScott View Post
  9. Likes UmmScott liked this post
  10. #85
    Jan 2016
    Just matching the wattage of the motor isnt enough you gotta match the type of motor to...some kinds of motors do not develop enough torque so they will not come up to speed.
  11. #86
    Feb 2016
    Louisburg Kansas
    Tach the motor speed and compare to the nameplate. Compare that information to the motor you replaced.
