Results 1 to 13 of 14
    May 2005
    tecumseh B7616 compressor
    Need the new number..
    Let's give nukes a chance.
    Mar 2015
    Medford, N.Y.
    Tec MN#B7616 was/is an AJ4492A and that is a AJA4492axa,axb,axd, r-12 hi temp
    May 2005
    Ok..Im interested in replacing this compressor with one that will pull a walk in down to "beer" temp (37*) should I go with a AJ4492?
    Jan 2010
    Switch to a R404a compressor.
    May 2005
    Hmmmm its a cap tube system ..Ill get the room size and see if we can figure out a cap tube size..
    Southold, NY
    Quote Originally Posted by primmers View Post
    Being a cap tube there should be no problem changing to x-valve and receiver, then 404a
    May 2005
    Im not interested in redesigning it.....Ill just go with 401a and keep it as it is...Thanks...
    Aug 2009
    Maine
    I think the beer coming out of the tap is supposed to be 37*
    Chicago, IL
    Keep it as is, but go with a 134a compressor and 134 refrigerant. If you a changing a compressor on any system there is no reason to charge with an r-12 replacement blend.
    Aug 2009
    Maine
    As long as the oils is compateble.
    Quote Originally Posted by craig1 View Post
    Jan 2010
    [QUOTE=primmers;22088411] pull a walk in down (QUOTE]
    Must be a pretty small walk in to be using a cap tube system. Only time Ive ever seen that was at a Subway on about a 4' x 6' box.
    If this is the case, I can't see it holding much gas. Using a over priced HCFC refrigerant wouldn't be much a factor then. Might avoid the all to infamous, plugged cap tube, syndrome.
    Aug 2009
    Maine
    How many plugged cap tubes have you come across with R 409 or even 404? Hell even 22?
    Jan 2010
    Quote Originally Posted by lytning View Post
    Exactly, as oppose to R134a.
