Results 1 to 13 of 15
    Aug 2012
    Portland, Or
    Help with Coleman manufactured home gas furnace
    Gentleman
    I need help with a manufactured home gas furnace. I don't see to many. Attached pics. System lights, but flame just kind of floats. Stays lit, fan pops on but flames just floats, and no real heat comes out of registers. I checked gas pressure its of 6.5" and 3.5" wc coming out. It's got a deflector that flame is supposed to hit in heat exchanger. Cold air out of registers cause not enough of a flame. Heat exchanger ok, turned fan on and off flame didn't change. I think it's just a single office on burner. Not enough flame to do anything. Anyone familiar with this Coleman furnace.Name:  image.jpg
Size:  71.0 KBName:  image.jpg
    Aug 2012
    Portland, Or
    Direct vent, and I opened up system and added air where gas valve mounts. No change. Natural gas. What's the brass fitting with blue rubber on it?
    Mar 2012
    North Vernon, Indiana
    Spider in orfice
  4. Likes kamersoutdoor liked this post
  5. #4
    Feb 2007
    Fremont, Indiana
    Quote Originally Posted by Brown Tech View Post
    Spider in orfice
    This
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
  6. #5
    Athens, Ohio
    X2 on spider since gas pressure is correct.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  7. #6
    Aug 2012
    Portland, Or
    Your probably right. Thanks
  8. Likes kdean1 liked this post
  9. #7
    Virginia
    Quote Originally Posted by Iceman_pdx View Post
    I emailed you the service manual in case you want to review them.
  10. #8
    Jan 2005
    West Central Illinois
    x3 on spider or spider web in orifice.
  11. #9
    Apr 2011
    Cayuga, In
    Just had same thing little while ago. It was a spider and web in orfice, same furnace.
  12. #10
    Spider. Me too. Found many times.
  13. #11
    Dec 2015
    Yep a spider will do it. Also if you don't know what the brass fitting with the blue coating is you probably shouldn't be working on it.
  14. #12
    Aug 2012
    Portland, Or
    YES it was a spider!
    LDD we don't see many manufactured house gas furnaces out here. 99% of all manufactured house units are heat pump systems. First time I've seen this gas valve. I just saw a blue cap and didn't look at it. A little different looking than my regular GV. I just hopped on here asking a question. So thanks for the tip dude. Pressure regulator
    Just got back to job, customer was out of town for holidays and they had a fireplace till I got back. Late night call Xmas eve and I hate when I'm in a hurry and if I can't get back to job at least I can hop on HVAC-TALK till I return. Thanks guys and yes it was a spider and a nest in orfice. Dumbass here always appreciate the help from you guys
  15. #13
    Dec 2015
    Iceman glad you got it working that's whats important. The brass fitting with the blue coating is the gas connection line it is pretty common on most equipment. I will say however it is usually yellow, I would check that one and make sure it as an AGA or UL rating for gas use.
