Results 1 to 9 of 9
    Dec 2015
    Mini-Split Ductless System With Separate Humidity Control
    Are there any mini-split ductless systems that allow you to set a desired humidity level (e.g. 40%) in addition to setting the temperature?
    We're looking to install a min-split ductless system in our basement to provide air conditioning and humidity control. The problem is, on most days, the temperature doesn't rise enough to turn the AC on, but there's is still an ongoing need for humidity control. We still need cooling capacity for really hot days so a simple dehumidifier wouldn't suffice.
    Again, we're looking for a mini-split ductless system brand/model that has separate humidity control feature.
    Thanks for your help!
    Southold, NY
    Yes
    a dehumidifier is generally all that's needed in a basement.
    Teddy Bear will be along shortly
  3. Likes kdean1 liked this post.
  4. #3
    Dec 2015
    As noted in the post, we're looking for AC as well for days when it gets hot in our basement. Do you know of a mini-split ductless system brand/model that has separate humidity control feature?
  5. #4
    Southold, NY
    Your confusing an A/C with a dehumidifier! An A/C is designed to remove heat, a byproduct is moisture removal. (Computer room systems have the capability to control humidity without lowering temperature not recommend for the homeowners basement.)
    Dehumidifiers are designed to remove humidity without changing temperature.
  6. Likes kdean1 liked this post.
  7. #5
    Jun 2014
    Dover, DE
    A mini split, or any standard air conditioner, cannot remove humidity if there is no heat load. So it cannot remove moisture without lowering the temperature. Most basements have such low cooling load that a simple dehumidifier, sized for the space, will be all that's needed.
    There was a new member that wandered by here not long ago. He had an oversized mini put in his basement and expected it to dehumidify. It actually wound up increasing the humidity because of such short run times related to low load.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
  8. Likes kdean1 liked this post.
  9. #6
    Many mini splits have a dehumidify setting. It will over cool the area though.
  10. #7
    Oct 2010
    Without some type of reheat no air conditioner will dehumidify without lowering space temp.
    A minisplit and a standalone dehumidifier is your best bet.
  11. Likes kdean1 liked this post.
  12. #8
    Dec 2015
    Quote Originally Posted by jtrammel View Post
    That's frustrating. Two machines to accomplish one goal. Also, standalone dehumidifiers tend to be noisy.
  13. #9
    Dec 2015
    Makes sense. Thanks
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
