Thread: BRAND NEW FLOAT SWITCH FOR SCONDARY OUTLET OF DRAIN PAN
    Apr 2008
    Delray Beach, Florida
    This is another one of the new products that I have been working on. Please let me know your thoughts on it. The New Model AA2-FS Float Switch for the secondary outlet on the drain pan is designed to be more sensitive by allowing it to sense a small amount of condensate that overflows into the secondary outlet of the drain pan. The float switch comes set at the lowest level but can be easily adjusted for less sensitivity if desired. It also is very compact allowing it to fit into tight spaces and finally it allows you to inspect the float without removing it from the device by simply opening the top cover. Watch the video to see how it works before commenting. https://www.youtube.com/watch?v=sdT-...layer_embedded
    I mistakenly had it under the AA3 thread so I moved it to its own thread.
  2. Likes Imajoker liked this post.
  3. #2
    Apr 2015
    North Texas
    I like it! I have been thinking of using the overflow switch to power a relay that opens the call for cool and closes the trouble light at the Pro Focus 8000 thermostat. I have a daycare that has ten 5 ton upflow split systems that are located on a second floor. The systems are sitting in drain pans, but I could use the trouble light to email me when they have a condensate issue.
  4. #3
    Apr 2008
    Yes that will work. Great idea.
    The New switches are now available for distributors to bring in. Many have already ordered them in.
    Thanks for your feedback.
    The Model AA3 condensate float switch for auxiliary drain pans and the AA2-FS for secondary outlets of drain pans.
    AA2-FS VIDEO https://www.youtube.com/watch?v=sdT-...layer_embedded
    AA3 VIDEO https://youtu.be/2mgPEQDjevs
  5. Likes Imajoker liked this post.
  6. #4
    Apr 2008
    Special Price
    Quote Originally Posted by soaker View Post
    Just wanted to let you know that to try to get the product out there I am offering a special on it.
    See the attachment!!2016 special promotion SPX.pdf
