Ascend jimex reach in cooler help!
I am trying to find a schematic for an Ascend reach in cooler jgd48rs series. If anyone can help me I would appreciate it very much
The best help I can give is to tell you to push that thing out side and get someone to help you lift it into the dumpster. That company went out of business, for good reason.
I did find a link that has service info for a jfd-48. The wiring diagram is on page 27. I don't know if that is close enough or not, but either way I recommend trying option 1 first. Good luck.
https://www.google.com/url?sa=t&rct=...,d.eWE&cad=rja
Thank you I figure as much. The unit us a ***** to work on and the customer is very persistent on keeping it. I appreciate your help I've been looking for hours and couldn't find anything! The light bulb in it works but only for a few seconds before shutting it off, so I'm hoping the schematic will help me figure it out
The wiring is very different from other reach ins! I figure there's to much power running to the light, or a bad door switch I'm not sure I'll have to figure it out
Door switch? Is this a freezer or cooler?
It's a cooler and probably a bad starter. I'll just switch them out and see, if not, the ballast is my next step, but I highly doubt it's the ballast.
I can't find the starters for the unit at all. Usually there up in the top assembly but I can seem to find them! Would I have to pull the evap cover off to locate them? It's a two door glass sliding. The top assembly has one fluorescent lamp and the inside has another
Been a long time since I've seen a starter on anything
Wire some LED's and call it a day
- You may not post replies
- You may not edit your posts
Forum Rules
