    Dec 2013
    Assembling Pittsburgh lock made easier
    My company does lots of commercial and some residential. There's tons of double wall in the commercial side of the business and banging together all the double wall is hell, not to mention all the 18ga large Pittsburgh locks. Some of the guys use these Lock Blocks and i tried 'em myself, I got a couple and in my opinion they are the best thing out there. assembly time has been cut in half.The company is airseamsolutions.com
    Oct 2012
    Where we mow our own grass
    Will you send me some free ones?
    Oct 2010
    Quote Originally Posted by Mike19 View Post
    Take a block of steel and cut it with a bandsaw about 3/4 of the way through...
    Nov 2015
    Toronto, Ontario
    Get a pneumatic hammer and then you'll be in heaven. I counldnt imagine hammering 18ga together manually all day. I've always used hand folders to about the same effect as those lockblocks. A good pair won't mushroom too quickly and you could get about a year out of them.
    New Mexico
    Quote Originally Posted by Mattmm View Post
    There is also an electric version but absolutely get away from anything by hand. You don't use a hand saw anymore, right?
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Nov 2015
    Destin, FL
    18 ga is kind of tough to be knocking over a 1/4 edg of a hobo connection with an Estwing hammer all day.
    Pneumatic air hammer only way to go.
