Originally Posted by
jman2794
Static pressure would build on the supply side any where on the supply side. So think about it this way in the RTU you would still be on the supply side. Drill a tap into RTU cabinet and your still on the supply side just make sure it's after the blower wheel cabinet. Return side yes you can take measurement before filters same thing drill Into cabinet just mark where to not hit anything you shouldn't. These are good place to use for your delta t and static pressure.
