Results 1 to 13 of 19
    May 2005
    Whats the superheat on a scroll compressor??
    Im getting ready to replace a 3 month old compressor , the last one has the same symptoms (it went over a year)
    as this one…It seems like its flooded back and took the bearings out..but I checked superheat
    1.2 dozen times after the 2nd compressor.
    The TXV is good, I can get any superheat I need.
    Water cooled system..and its a walk in freezer.
    Let's give nukes a chance.
    Dec 2014
    In my truck, driving
    On a scroll the lower the better but be sure you have no flooding. I use an electronic sight glass to make it easy. But less than 5 is risky.
    Southold, NY
    20 - 40 at the pump
    Discharge below 175
    May 2005
    Well I set it at 25* give or take a couple, and its toast…..discharge was around 175 as well….Im wore out on this one..
    going to go get a replacement compressor tuesday…hope something clicks.
    Off cycle migration? I know you said it's a WI freezer, so maybe this is not as much of an issue. Oil heater working?
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    May 2005
    The system is in a warm underground area..
    Jul 2000
    Guayaquil, EC
    Is this set up for pumpdown? For both the off-cycle and for defrost? Is the low pressure control sticking closed? Did you replace the contactor? How's the oil level? (I assume it has an oil SG)
    Quote Originally Posted by primmers View Post
    That does not mean much!
    May 2005
    icemeister, Yes it pumps down, on both…the low pressure control is electric controller that does it all…No, i didnt replace the contractor, but will be eyeballing it tonight when I remove the compressor..
    theres no sight glass on the compressor..
    coolpeferfect, now that I think of it theres a heater on the system..
    May 2005
    I read a piece on compressor super heat and it called for 40*……said you couldn't flood the compressor at that temp..
    Jul 2000
    Guayaquil, EC
    theres no sight glass on the compressor...
    Since it's a pumpdown control, there no migration issue.
    What model is the compressor? Is Copeland not putting SG's on refrigeration scrolls now?
    It's good practice to replace the contactor with every compressor change. Cheap insurance.
    Dec 2014
    How about the suction line, is it well insulated?
    Southold, NY
    2nd on in 15 months request a tear down and find exactly what happened.
    I assume R-404A
    MOP x-valve?
    Could just be It Happins!
