Results 1 to 2 of 2
    Sep 2015
    Confused Battery Backup Navien Gas Water Heater/Water Boiler
    I have a Navien Model CH-210 combination tankless water heater/water boiler located in a home that is frequently unoccupied during the winter months. This area is prone to very cold weather and periodic power outages - when this happens the unit shuts down, which means the radiant heating system also shuts down. I'm searching for a battery back up unit that will keep this unit operational till power comes back on. It's a 120 volt system with max power requirement of 200 w per owners manual. Any recommendations would be appreciated.
    Jul 2015
    Forest City
    If the power stays off for a very long time battery backup may not be the best ,you may want to look into solenoid drain down valves to drain your heater when you loose power.
