Page 4 of 4 FirstFirst 1234
Results 40 to 48 of 48
  1. #40
    Aug 2015
    For an idea of cost, search Ultra-Aire, plenty of prices out there.
    Because of the technical nature of the products, suggest getting a local a/c contractor to sell and install. It will cost a little more but well worth it.
    Your tech needs to get the a/c working correctly and doing its part of humidity control. A small whole house dehumidifier is intended to keep a home dry during low/no cooling loads and high outdoor dew points.
    Your cooling cost will not go up and your home will be much more comfortable.
    Regards Teddy Bear
    Does the Ultra-Aire hook up to my mini-split or my other traditional A/C system? I'm just wondering how it would help upstairs where the mini-splits reside.
  2. #41
    Aug 2015
    Regards Teddy Bear
    Can you elaborate on what you mean by "your tech needs to get the a/c working correctly and doing it's part of the humidity control". Are you talking about the mini-splits?
  3. #42
    Aug 2015
    Quote Originally Posted by jrbenny View Post
    So what size was that ptac?
    Not sure, I will try to figure that out tonight when I get home.
  4. #43
    Aug 2015
    Does anyone know how I could determine the cost breakdown of my system (parts versus labor). If I were to remove the system, is there any way to recoup some of my cost?
  5. #44
    Cincinnati, Oh
    Quote Originally Posted by Hammer09 View Post
    Ahh...
    So what happened?
    "Just get it done son."
    Dad adjusted
  6. #45
    Aug 2015
    Quote Originally Posted by hvacvegas View Post
    Ahh...
    So what happened?
    Nothing yet... I'm just trying to figure out if I should have the system removed and if so would the system have any value so that I could recoup my investment.
  7. #46
    Madison, WI/Cape Coral, FL
    Working correctly means setting up the a/c to provide 50%RH during extended operation. Or best as possible. Maintaining 55%RH is ok for some. This is important before adding supplemental dehumidification to avoid making the dehumidifier run more than needed.
    In the case of mini-splits, dry air the dehumidifier should be circulated as best as possible. At a minimum to the open part of the home. The dehumidifier can be located in an utility area or closet.
    Hope this helps.
    Regards Teddy Bear
  8. #47
    Aug 2015
    Thanks, that is helpful.
  9. #48
    Aug 2015
    Hope this helps.
    Regards Teddy Bear
    Thanks, that is helpful!
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
