+ Reply to Thread
Results 1 to 15 of 15
Thread: flare tool issue
    Confused flare tool issue
    http://www.amazon.com/Yellow-Jacket-.../dp/B002SB5RMA
    Every flare I make with this device leaves 3 indents on the flare face. It seems to coincide with the 3 lines on the cone itself.
    I have watched the online video, tried different pressure stop points and tried releasing the finished flare different ways- still does it.
    Anyone else use this tool with success?
    Aug 2009
    Maine
    Never had a problem with mine, do you use nylog on the cone? I also use the Hilmor no problem there either.
    Mar 2013
    Treasure coast, FL
    Try annealing the copper. You could have a crappy pipe.
    Sent from my SCH-I545 using Tapatalk
    Quote Originally Posted by shellkamp View Post
    Many different test pieces used and same thing.
    Quote Originally Posted by lytning View Post
    I use vac or refrig oil, have not tried nylog when forming flare.
    Jun 2013
    Northeast Wi
    I have made several flares with this tool and never had an issue with this tool. Couple times I did tighten the clamp enough and the pipe slipped a little and had a short flare. I yelled at the tool reflarred and all was good
    May 2009
    South of Heaven
    The 1/4 inch size on mine gives me problems staying clamped in sometimes ( the red handle model that pre dates this never had this problem ). Other than that it works well for me.
    Feb 2015
    Coastal South Carolina
    I use a little Nylog on the cone and it works great. I did have a couple of times where the 1/4 inch did slip, figured it was just me...maybe it wasn't me?
    When your flare is done, does it fill the "bowl" in the bottom die?
    I have yet to see this happen, and not sure it is supposed to as that would seem to be too large of a surface. Referring to 1/4 - 5/8.
    I believe I have seen these marks you refer to created by this tool. However, the indentations are on the back side of the flare cone and not on the burnished, sealing surface, so I would think they would not be critical.
    "Knowledge is what you get when you read the directions. Experience is what you get when you don't." --Unknown
    Jun 2013
    Northeast Wi
    1/4" slips on mine to.
    Mar 2013
    NJ
    Quote Originally Posted by 11crv View Post
    Mine also slips when backing out 1/4", inconsistent flare outside diameters too. 458r is a much better tool in my opinion
    Jan 2016
    Rhode Island
    had a few times my would slip with 1/4 inch, but would also do it with my ridged flare tool. I thought maybe it was due to poor quality of the tubing.
  14. #14
    Sep 2013
    NM
    I've always had issues with making the 1/4 flare with this tool too,
    It's been hit or miss. The rest of the sizes I've never had a problem and it is my favorite flare tool.
  15. #15
    Apr 2012
    winnipeg
    dont use that tool...... never had a flare go bad in 30 years..... something fishy
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
