Results 1 to 10 of 10
    Jan 2015
    East Tenn
    LIQUID LINES SWEATING PROFUSELY - This is what I did !
    I have a Brick Home and any Lines that Run through the Brick and Block - there is an Inch Air Space
    .75 - 1.5" Space on some Homes _ there is also a lot of Moister in these Walls ..
    That's why a lot of _ Mason's Install Weeps . Any How - I was getting Continuous Drips .. New Install ..
    Ended Up Drilling Holes All around the Freeze Board where the Lines ran through Block or Brick and Blew _ Half a Can
    of Insulating Foam into the Wall _ Between the Freeze Board and the Outside , Brick & Block ..
    Solved the Issue . .
    Oct 2010
    If the liquid line was sweating then I know that no amount of insulation will solve that problem. The vapor line, yes. The liquid line, no.
    Jan 2015
    East Tenn
    Sweating May Not be the correct Term and Small Lines it was the High Humidity in Southern Homes Combined with NO WEEPS
    as they Don't want Bugs getting in and ( Yes I have seen Tight Screens Used for the Weeps ) -
    They don't seem to due that Either in the South .
    The Pipe simply Acts as a Pathway ..
    Jan 2015
    East Tenn
    If the Installer _ Drills the Holes to Close to the STEP at the Top of the Wall from Basement to the Step for the Brick .
    It Simply Starts a Path ..
    It's a Possibility that some with Brick Home _ have this Condition .
    Mar 2009
    Mount Holly, NC
    You might contain or stop the moisture from forming but you will not fix the REASON the liquid line is condensing. ..
    If the liquid line is below outdoor temp there is a refrigeration problem that needs fixing.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Click below to BECOME a pro member
    https://hvac-talk.com/vbb/forumdispl...ip-Information
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    Jan 2015
    East Tenn
    Quote Originally Posted by vstech View Post
    Agree :
    Read My Reply's Twice :
    See Diagram : It Could be all about the Construction on a Split System &
    Where the Holes were Drilled .
    [IMG][/IMG]
    Oct 2010
    No matter the humidity or any dew point the air would be the smaller LIQUID line on an operating AC system will not sweat unless there's a refrigeration problem. The Larger SUCTION vapor line will sweat under most conditions when operating.
    Jan 2015
    East Tenn
    In The Illustration Above - there is an Item Marked : Open Weave - Mesh .
    New Products of this Type are more Open and Help allow Air to Move and the Wall to Breathe .
    In Older Homes it was more like a Wick . ( If You Drill a Whole in a - Wick - Your going to get What ? )
    5% Points for Humidity Control
    Jun 2014
    Dover, DE
    You didn't solve the issue. Liquid line isn't suppose to sweat, period.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Quote Originally Posted by QualityAssure View Post
    The liquid line should always be warmer then the dew point when an A/C runs. So its temp should never be at or below the dew point. If a liquid line is sweating, there is a problem with the system.
    Your attempt at a solution for riverridge01, is the reason only the thread starter, and Pro * members can reply to threads in the AOP forums.
